Question about Tag Heuer Grand Carrera 17 RS CAV511B Watch
How to get the seconds counter working on grand
Watch is working perfect but the seconds counter has stopped
I just purchased a Michele chronograph watch and need assistance with stopping the "seconds counter". I don't know if it's suppose to constantly run or not. I also noticed my second hand seems...
It might have something to do with the timing function. Perhaps when you're not wearing it, you pull the stem out but not all the way? If it's pulled to the second notch and hit one of the 2 pusher buttons, you may be stopping it. And likewise, perhaps you're starting the seconds counter? Google Michele watch instructions for the PDF instruction manual for details.
Mar 21, 2011 | Michele MW Square Chrono 71-750-CC-311-180...
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
Feb 28, 2011 | Fossil Watches
If the watch is not worn for a day, is it normal for it to stop or slow down? Vintage SS mens datejust, oyster perpetual.
mcdevito75 here, Yes it is normal, especially if your Rolex is an automatic watch. The motion of your Wrist / Hand keeps your watch wound thru the Counter balance on the movement, as the counter balance turns it winds the mainspring little by little, thus keeping your watch wound. Once you take off your watch, if long enough the mainspring simply un-winds and slows and will eventually stop your watch completely. You can keep your Rolex wound even when you take it off by means of a watch winder, a small machine that will keep your watch in motion, or by hand, by rocking the watch back and firth in your hand for about 30 seconds, say before you gpo to bed at night, this way there is always some wind to your watch.
Aug 15, 2010 | Rolex Datejust SS
I am trying to set a digital watch, there are 4 buttons 1=light 2=mode 3=start&stop 4=lap reset. I can not find the name brand and I bought it at a second hand store for my grandson. The only name I...
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
Jun 23, 2010 | Watches
Why isn't the second hand on my Wenger Commando SR not working? The red seconds hand is not moving. The small seconds counter of the chronograph works and the minute and hour hands work.
The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
Jun 02, 2010 | Swiss Army Wenger Commando 70725 Wrist...
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
Seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
George watch
From the clock mode, hold the Lap/Rest button until the "seconds" counter flashes. Use the Start/Stop button to advance the time, use Mode to switch between hours, seconds, date, etc.
Sep 11, 2009 | Fossil Watches
The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Dec 20, 2008 | Watches
The (second(s) Counter Stick has stopped
is it a chronograph model? If so, reset the chrono. If not, you are going to have to send it in to a repair shop or the mfr to repair it...probably bumped it hard
Aug 14, 2008 | Breitling Hercules 246/GRY/PROF
Tag Heuer Grand Carrera 17 RS CAV511B Watch Logo
474 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
