Question about Comfort-Aire CS-101A Air Conditioner
ComfortAire window AC on the touch pad there are times when no controls work and the temperture flashes from 30 to 86, the fans runs and the compressor kicks on runs for a short period of time then kicks off. Does not run long enough to cool the room. Anybody know what is wrong with this AC just bought this Comfortaire July 9th 2010 ran good for one day and one night the started to act up please help.
  • Comfort-Aire Master
  • 2,153 Answers
Sounds like a bad control board
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Aug 04, 2017
2 Suggested Answers
  • 2006 Answers
SOURCE: just bought a comfortaire reg-253h,
Personal opinion only! All air conditioners have their good points and their bad points and the comfort aire is no exception. From the engineering standpoint it is uses to small of certain critical components so if you plan on running it at high all the time it won't last as long as a better engineered unit. But if you can run it at lower than high end, it will last for quite some time.
Posted on Sep 01, 2011
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
High temperture
Have you check the thermostat?
You might want to remove it and install a new one see it still overheats.
May 27, 2008 | 2006 Chevrolet Cobalt
Cooling fans only come on when ac is on what could be the problem
there is a fan control switch in the cooling system. since both fans run with a/c on, this is most likely your problem. you can check the fan relay and see if the switch is supplying ground to activate relay.
Jun 30, 2012 | 2000 Buick LeSabre
The fan motor is on all the time with the controls shut off. I have to shut the unit off with the main breaker. The ac works but again the fan never shuts off. On the circuit board the LED flashes 8 times,...
The indoor fan or the outdoor fan? If it is the indoor fan the thermostat may be wired incorrectly or shorted. If the red wire and green wire in your thermostat maintain contact, the indoor fan will run all the time.
Aug 03, 2011 | Heating & Cooling
I am using windows 7, 64 bit and when the fan starts to run, the touchpad stops working. any suggestions?
does it always happen to you? if it does what fan are you referring to?
if it is internal fan then you have a problem with the power supply or battery
try connecting the power adapter and check if both fan and touch pad will work at the same time.
also check the touch pad off function button. maybe there's glitch or something that automatically turns it off. try turning it on if it will work.
but then it is better to let it check by a laptop technician.
Apr 17, 2011 | Computers & Internet
Is another name for the fan module a temperture
cooling fan module or blower fan module. there is two different ones. radiator and ac heater you know
Jan 16, 2010 | 1986 Cadillac DeVille
Same problems need answers
i think the fan is supposed to do that and the a c might have to much or too little pressure
Jun 30, 2009 | 1992 Chevrolet Corvette
2006 toyota tacoma heat wont shut off
put a pipe clamp on one of the feed pipes for the heater that will shut if off
Apr 05, 2009 | 2006 Toyota Tacoma
TOW FANS AGAINST THE RADIATOR, TOYOTA CAMRY 2001 4 CYL
yes, they are both radiator fan. dependent on the temperture of the outside air and the cooling temperure on control panel. the fan will kick on when the temperture cross over the preset- set on the computer. so, either fan on, no fan, fan is runing when the car is runing or not, is not a porblem.
the porblem occures when the fan stops, and the temperture is over 100 degree outside.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
Comfort-Aire CS-101A Air Conditioner Logo
63 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Marvin
Marvin
Cesar Quant
Cesar Quant
ray gallant
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
