Question about Toshiba REGZA 47HL167 TV
How can i connect my dell laptop to my toshiba flat screen tv
    Guru:
  • 276 Answers
My os is vista how can connect to my jvc flat tv as a second monitor?
How you connect to your tv is not so much a matter of OS as it is dependent on what type of video connections are available on your laptop whether RGB, S-Video, mini-display port to DVI, or HDMI.
Once the tv is connected then you will need to right click your desktop and choose whether you want the tv to be a clone display (desktop to show on both your laptop screen and the tv, or use the extended desktop setting to have half the screen be on the laptop and the other half to be on flat screen tv.
Mar 10, 2014 | Dell Latitude E6400 Notebook
How to connect laptop to flat screen TV
You can use a VGA cable to connect to your flat screen. Then select the RGB input your tv and it should work. If your computer is new and high end enough it may have HDMI out and then I would use an HDMI cable.
Apr 01, 2013 | Viore Televison & Video
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
How to use as monitor for laptop
i assume the TV has a VGA port (blue 15-pin) and that you're using a VGA cable.
the TV will usually have another A/V or input specifically for the VGA which can be called anything from "PC" to "other" make sure you've got that input selected
once you've got all that tell your PC to connect (button looks like a box with a line on each side) by pressing "fn" + "f4" if you have an HP...i think dell uses "fn" + "f8" i think Asus uses "fn" + "f5". (**usually if you press it once it will turn off your comp screen and transmit to tv, if you press a second time it will go back and if you press a third time it will tranmit to both at the same time)
if this is the first time you've connected your laptop to something it usually brings up a screen to configure some options like do you want to mirror the screen or use the tv as an extension of the screen.
hope this helps
Thomas
Feb 16, 2010 | Toshiba 20VL33 20 in. LCD Television
Connect Dell Latitude D600 to TV
try holding down the fn button and pressing at the same time the button with a small screen on it will do monitor switching
Aug 06, 2009 | Dell Latitude D600 Notebook
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I want to connect my Toshiba Satellite A305-S6863 Laptop to TV
You have to configure yout laptop to output through the s-video (which does not carry sound, so you need to either use the laptop speakers for sound, or the line output (headphone jack) to the TV).
I don't know if all toshibas are the same, but with mine, if I hold Fn (near the windows key) and press F5, it will change the output, do it a few times until you see a picture on the TV, some settings make this your extended desktop, meaning you can drag a window from one screen to another.
Apr 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba REGZA 47HL167 TV Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
