Question about Maytag MAV3955E Top Load Washer
I have a Maytag 3955eew Top-load Washer that is four years old. It won't spin out. The inner drum won't turn. It does agitate and drain properly, Motor runs in spin mode same direction as agitate mode. I have replaced the brake/clutch/bearing but same results. Inner drum does not have any visible obstructions (I removed the inner basket to check). Belt is in good shape, doesn't appear to be slipping at all. What next ? Tx
    President:
  • 1,554 Answers
The motor runs during the spin cycle in the same direction as during the drain only cycle. Since the machine drains properly, this is a clear indication that the issue is not within the motor. The motor should run in opposite direction during the spin mode, not in the same direction as during the agitate mode. This is a clear manifestation that the motor is not switched to the spin mode which the timer failed to do so. The issue is definitely with the timer and not with the motor, transmission, nor the brake/clutch/bearing.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from doing so. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 11, 2010
  • Jahn27
    Jahn27 Jul 11, 2010
    Replace the timer (part number 21001959) to address the problem.
  • Jahn27
    Jahn27 Jul 11, 2010
    The inner drum does not turn because the brake is not released which happens only when the motor runs in the opposite direction and turn the clutch in which the clutch tab pushes the brake cam driver and release the brake.
Trying to diagnose a problem and have back panel off. Belt was off AND I think the cause is that the drum pulley and inner drum will not spin without a lot of pressure. I figure the motor (which appea
Either something is caught between inner & outer bowl or drum bearings need replacing. Also check outlet hose going to pump sometimes object caught there causing the bowl to be tight to turn.
Dec 11, 2013 | Maytag MAH2400A Compact Front Load Washer
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
Old maytag A208 will not spin
I would say, there is something holding the inner drum from rotating. Possibly an item of clothing that has slipped between the drums.. When washing only the agitator(pulsator) moves, when spinning, the complete drum rotates as well. Remove obstruction.
Sep 21, 2009 | Maytag PAV2300 Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Nov 07, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Maytag MAV3955E Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
