Question about Philips 26MF605T/17 26 in. LCD Television
Flst Panel TV model number: 26mf231d/37
TV no picture was told we need a new program for it. Dowloaded program sent to us.Program was older that the TV. Please call or e-mail with the correct program to be installed via flash drive.I have been trying to get this problem resolved for a month. Would love to watch my TV.I really don't want to have to drive it 100 miles for repair then drive another 100 miles to pick plus pay for repair. Thank You Sherrie Lubbes
  • 12 Answers
sounds like the Y to replace all 3 at same time main and buffer upper and lower
Posted on Jul 21, 2008
  • 5 Answers
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Posted on Dec 06, 2008
SOURCE: No Picture just 4 red blinking lights
Look For TWO 10 Volt 33000 mfd. Caps That Appear To Be Swollen,They Are Next To Each Other At The Bottom Of The Power Supply Board, Change Them To 16 Volt Versions.
Posted on Mar 01, 2009
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Posted on Nov 03, 2009
  • 25 Answers
SOURCE: i have a magnavox 26MF231D/37 lcd tv. It has good
Either your inverter board or video board is bad. If you can see picture while the TV is on then its your inverter board. If not, video board.
Posted on Nov 05, 2009
I need a remote code for a Panasonic TV, Model Nr. CT20658 to program my Infinity remote. Thx in advance.
0048,0042,0041. Try these codes. For more information Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 01, 2013 | Emerson EWL3706 37 in. LCD Television
26MF231D 37 Inch. Green Blinking Light - will not power on.
These blinks are fault indications, and are called blinking codes. For Philips brand TVs, we cannot count these blink directly; there is an other way to count these, and should be converted to error codes numbers. If you wish to get more details about how to count these blinks to Philips brand TVs, check the link sited here. After converting these blinks to error codes, you can get an idea about the faulty circuit stage inside the TV. Check this link. Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 15, 2013 | Philips 26MF231D 26 in. LCD Television
I cannot find my manual for my tv. We have moved and i think it got lost when packing and unpacking. I would like to get a new one thank you for your time.
Try LG website might can be print for free.Might be gone,because as tv models get older it taken off.Phone number on the website.Try call LG customers service pay them a fee.They'll sent it out to u.
Oct 21, 2010 | LG 37LG30 37 in. LCD HDTV
Insignia tv remote programming
An owner's manual for your TV can be found at, just search for your TV's model number and click on the Support tab. It should include complete instructions for programming your remote control.
Feb 12, 2010 | Insignia 37" LCD Flat-Panel HDTV
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
I have a magnavox 26MF231D/37 lcd tv. It has good sound but no screen, just black. Turn it on and off aqnd it doesn't flash no anything. thanks
Nov 05, 2009 | Philips 26MF231D 26 in. LCD Television
Program code for olevia 37 to direct tv remote
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to - accessories - remotes.
Mar 15, 2009 | Olevia LT37HVS 37 in. LCD HDTV
i got the same model tv, and had the same direct tv and tell them you just got the new polaroid tv...i take it you got it at wallmart......anyway,call them up and tell them you want them to send you a updated remote...since the tv is so new,(came out in october of 08)...your older remote doesnt have the new code for it.
Nov 30, 2008 | LG 37LP1D 37 in. LCD Television
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Open Questions:
Philips 26MF605T/17 26 in. LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
