My Beogram cd 6500 has a problem -- I cannot remove a cd. The eject command does not seem to work.
2 Suggested Answers
  • 122 Answers
SOURCE: My beogram cd 50 is not working - it will not read
YES THE BEOGRAM CD5500/6500/7000. ALSO ANY CD WILL WORK THROUGH THE CD CONNECTION JUST USE A 2 PHONO TO 5 PIN DIN PLUG ADAPTOR,NO R/C OPERATION IS POSSIBLE UNLESS YOU USE A B&O PRODUCT.
Posted on Jan 27, 2010
Show a diagram on how to get cd stuck in 2006 f150 out. Cd stuck and tried but it won' come out
Look to see if there is a tiny hole on the front of CD player just under the tray.that is the access point for a paper clip.if there isn't one...try turning ignition off then whilst holding the eject button turn on the ignition and do not release eject button.
you may need to try this several times.what you are trying to do is beat the cd from trying to read the cd as this seems to over ride any eject commands on some machines.if all of the above fail you may need to remove entire unit from dash to gain access .
Feb 12, 2015 | Ford F-150 F150 Extended Cab
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
The cd wont eject from cd player in my seat ibiza 1.4 diesel 2010
Open my computer and right click DVD icon and also option show eject and press it.
Open command prompt and type command, like your DVD rom drive name "E" then go to E drive under and type eject Command.
If not solved then i share a link please visit and read it. and follow instruction.
http://www.wikihow.com/Remove-a-Stuck-CD-from-a-Car-CD-Player
Thanks,
Apple Technical Support
Jun 09, 2014 | Computers & Internet
I have macbook i can not eject the cd from laptop
Do you just want to remove the disc or fix the issue with not been able to remove from the computer?
To remove the disc try going to finder, one is display you should be able to see an icon that looks like a disc. Next to it there should be an eject icon, click the eject icon and your disc you come out.
Mar 12, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
My daughter put a small disc for her music in my mac computer how do i get it out
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.Alternatively follow the following instructions: How do remove stuck Mini CD from the SuperDrive on Macbook Pro
Dec 29, 2010 | Apple iMac OS 9.1
My beogram cd 50 is not working - it will not read the disc and the door just opens. Is there another cd player that can connect to the beogram 5500 system?
Jan 15, 2010 | Audio Players & Recorders
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Dvd stuck in ibook g4 disc drive
Here's possibility 1: from the apple forums" We had a repair come in at work with excactly the same issue, I managed to correct the issue by correcting the CD-Drive connection to the logic board, the customer had a very VERY big smile on his face once I had fixed. I felt so happy after this repair, unfortunatly, it earned our AASP no money tho. But it made me happy to see a smile I caused.
Possibility 2: firmware command:To eject a disc with Open Firmware commands, follow these steps:
1. Restart the computer .
2. Immediately after the startup sound, press and hold the key
combination Command-Option-O-F.
Note: The Command key has the Apple icon on it.
3. Release the keys when you see a white screen that says "Welcome to
Open Firmware."
4. At the prompt, type: eject cd
5. Press Return, then wait a few seconds. The disc drive should eject
any disc that is present, and "ok" appears behind your command when the
action is complete.
6. Type: mac-boot
7. Press Return.
Possiblity 3
If you can't get the CD to eject normally, reboot and hold the Option key. You'll see a startup drive select window. When the cursor changes to an arrow, (be patient, it may take a minute or two) then press your eject key, the CD will eject. You can also try holding the mouse/trackpad button down during a restart.
Jun 04, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
136 people viewed this question
 Grubhead
Grubhead
