Question about Peg Perego John Deere Gator HPX
Spitting oil and gas out from exhaust - Peg Perego John Deere Gator HPX
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 08, 2012
50cc scooter spitting oil out of exhaust
I guess you people cant read, he said it is spitting oil out the exhaust, thats has nothing to do with spark plug or carb cleaning...the oil injector is stuck open putting to much oil into the mix....
Mar 13, 2012 | Motorcycles
Is it bad for the exhaust to spit out water?
A cold morning start normally withe a perfect fuel tuning will have water come out from the exhaust as drops or has fumes. But if you sense there is a heavy flow with a possible engine missing then the oil within the engine must be checked to confirm if there is any damage on the enigne block or the water gaskets. Make sure that the oil sensor switch connection is intact.
Jan 07, 2012 | 2007 Ford Focus 2.0
Gas is spitting out of the exhaust
Check your oil. If it is too full , change it. Occasionally the Honda's of that time would have the float stick and fill the engine with gas. There may actually be nothing wrong with your cycle , new bikes did this. If gas filled the cylinder and went into the exhaust you probably have a stuck float. If the problem happens again you may have to disassemble and clean the carburetors , replacing the float needles at that time. One good way to keep your oil from filling with gas is to always turn off your gas at the fuel petcock after riding. Be sure to check your air filter for gas/oil saturation and be sure to pull the plugs on your pollution tubes under the air box to drain the blow by.
Oct 23, 2010 | 1984 Honda VT 500 C
Spitting oil
you put too much oil on your engine, 2.8L without filter change. 2.9L with filter change is the recomemded if you exceed you bike will spit the excess oil sometimes the oil goes to air cleaner have your air cleaner check and cleaned
Oct 27, 2009 | 2002 Aprilia RS 250
Oil droplets coming out of exhaust
I don't think its oil most likely its condensation, this happens when the exhaust system is cold and engine exhaust is hot creates moister and its got to go someware. Unless you see a lot of blue or white smoke comming out the exhaust i would not be to concerned.
Apr 13, 2009 | 1995 Eagle Talon
Oily watery stuff coming out off the exhaust, oil pump is set ok
is this bike a yamaha rd 350 twin cylinder 2 stroke? if so, its air cooled and you should not be getting a ltr of water.. but it is common for them to have a "oily" fluid come out the exhaust because it is a 2 stroke. but not alot. it comes from the engine not burning all the oil gas mix. does the engine spit and sputter? make sure there is no water in the tank, make sure the air filter is clean and buy hotter spark plugs. also adjusting the fuel air mixture may help. hope this helps...
Mar 11, 2009 | 1986 Yamaha RD 350
Ford C4 Auto gearbox spits oil
It sounds like it could be overfilled, but that will be easy enough to check on the dipstick. Should be checked with the engine idling in neutral. Otherwise, the trans could be overheating, causing the oil to expand to the point that it spits out the breather. Pull the dipstick and check the fluid condition, if it's dark and smells burnt, the trans may be slipping or overheating for some other reason, and it's probably time to get a trans shop involved. You should probably run an auxiliary cooler at the radiator area in the type of application you describe, especially if you're gonna be using the gas pedal fairly heavily! Sounds like a sweet car, lots of fun to be had in something like that.
Oct 25, 2008 | 1983 Ford Fairmont
Peg Perego John Deere Gator HPX Logo
62 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
