Question about Pulsar Watches
REMOVE STEM FROM PULSAR DIVE WATCH - Pulsar Watches
SOURCE: removing the watch stem
Hi, it depends on the watch . Look carefully ,if there is a release button , somethin you can press on or lift up. Sometimes a needle is enough to do the job. On some quartz movements (the cheap ones) you just can't remove the stem ...
hope this will be helpfull!
K.
Posted on Apr 11, 2008
billfox1966
  • 231 Answers
SOURCE: condensation in dive watch
place the watch in a bag of minute rice for a day or so and check to see when its becomes clear. this tip,i will guarantee it to work in no more than a few days. be sure to loosen the stem and even the back acess to the battery to insure the moisture can escape from the watch
Posted on Jul 09, 2009
SOURCE: illinois pocket watch stem removal.
First you must say what type as there are differences depending on the mfg and model.Be the following basics apply.
1- Put the stem in the setting position (usually pulled out if stem set).
2 Them open cover to expose the movement. ( Screw off or snap open).
3- Remove the movement (Usually held in place with 2 screws at the outer edge.
4-Then if there is a screw in the part that holds the stem loosen that.
5- The stem can be held with a pair of pliers on the flat and the crown unscrewed. Be careful not to damage the square (FLATS), with the pliers. A rag or other safety measure should be taken.
6- then inside the stem hole, looking from the ouside the is an annular area around the stem that has a ferrule screwed into the case this has to be unscrewed and will bring out the stem and the ferrule.
This siounds complicated but the steps are more involved to write than they are to perform.
There are many variations to this process, and each type should be understood before proceeding.
mrmel.mrmel@gmail.com
Posted on Nov 24, 2009
SOURCE: how to remove stem from scotty pocket watch
did you figuer it out because i am having the same problem, i don't want to take apart the balance just to change the and fix the face
Posted on Nov 26, 2009
  • 93 Answers
SOURCE: I have a pulsar dive watch. How do i set the
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to buy world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service when your login.
Posted on Jan 07, 2010
How to remove crystal from Pulsar watch PF3142 chronograph to refit small seconds hand
There is usually a way to remove the crown and stem together so that the movement can be removed from the casing.
Have a good look over the movement and see if there are any identifying marks and let me know what you find. Alternatively, post a photo of the movement.
Oct 07, 2017 | Pulsar PXF100 Wrist Watch
I can't pull out the stem on my Pulsar watch to set the time. Any suggestions.
Because your timepiece is water resistant to 100m, you may have to unscrew the crown before pulling it out to set the time.
Aug 12, 2011 | Pulsar PF3293 Wrist Watch
Lost stem on watch. can i get replacement? can i install myself?
mcdevito75 Here, Pulsar a quartz watch. If you lost the stem, the mechanism holding it into the watch maybe damaged, this mechanism also turns your Pulsar watch on / off. Best Bet, visit a small watch repair shop in your area, have them take a look at your Pulsar watch. You could replace the stem yourself but first you"d need the right size stem, (hard to get) then if the mechanism holding the stem in is damaged you"ve wasted your time. Your local small watch repair shop can let you know, and they usually don"t charge to have a look.
Feb 05, 2011 | Pulsar PXH227 Wrist Watch
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
Watch stops when stem is fully engaged
It sounds like the setting mechanism has gotten out of place or is bent. A qualified watchmaker can fix this for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 05, 2010 | Luminox Navy SEAL Dive 3103 Wrist Watch
Condensation in dive watch
Jul 09, 2009 | Watches
I cant pull out the date/time pin on my luminox 3204. any suggestions?
On some watches - scuba usually - the crown has a rubber seal and that seal is engaged when the crown is screwed to the case. If your watch is like this, you need to unscrew the crown before you can pull out the stem. Twist the crown in a counterclockwise direction several turns. You will be able to tell when it is completely unscrewed because youwill feel spring tension. Pull out the stem to set the watch. When you finish, push the stem back in. Push against the spring tension and carefully thread the crown back onto the case. That should do it.
Jun 12, 2009 | Luminox Navy Seal Dive 3204 Wrist Watch
Stem came out, question water resistance of watch now
Hi
The crown or winder, should have a very small o ring inside it, which seals on the watch case. Normally when replacing the stem this o ring would be replaced and lubricated with silicone grease to ensure water tightness. If this was not done there is no guarantee that it will still be waterproof (please dont forget to rate my answer, thanks)
May 04, 2009 | Navy Seal Luminox Dive Watch
Luminox 3000/3900
I just fixed the same problem .There is a small arrow pointing to a small hole .insert a very thin screw driver or a pin and the stem will come out easily.
Jun 21, 2008 | Navy Seal Luminox Dive Watch
Watches Logo
177 people viewed this question
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
