The amount of water or the water level during the washing cycle is very little. is there some way to adjust the water level, so that more water is allowed to go in before it starts the wash cycle
  • ivanarybensk Jul 11, 2010
    I have a whirlpool AWO 9361 6th sense 6kg front load washing machine very similar to a AWO/D5926. How do I adjust the water level switch?????
  • 4,070 Answers
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear. Remove screws or pry up the spring clips to open the top to access the tube.
Posted on Jul 11, 2010
    President:
  • 1,554 Answers
High-efficiency washers are designed to use just the right (very little) amount of water for washing and HE detergent must be used for the machine to work properly. The amount of water that fills the machine during any cycle is automatically controlled by the controls. Adjusting the water level, as if possible, for the wash cycle will result in sud error. Therefore, adjusting the water level for any cycle is not possible. It also prevents the overloading of the machine which will result in the same sud error.
  • Jahn27
    Jahn27 Jul 11, 2010
    Your washer has intelligent electronic controls and there's no way you can alter the water level for any wash cycle except rigging the water level pressure sensor/switch which is a task next to impossible. Granting that you can devise a way to add water into the machine to make the water level higher than what the controls permit but without rigging the water level pressure sensor/switch, the machine will definitely not work then flash either a sud error or overflow fault code. Again, the only why to alter the water level is by rigging the water level pressure sensor/switch to allow higher water level.
    In case the water level is indeed below what is normal for a specific wash cycle, consider replacing the water level pressure sensor/switch and/or the water inlet valves.
  • Jahn27
    Jahn27 Jul 11, 2010
    By the way, you don't have to accept or reject
    and rate any solution/advice
    to post comments and follow-up questions.
    Accepting a solution does not stop you from doing so. You
    can continue communicating with an expert as
    long as you need assistance regarding the issue stated herein.
Splashing water during spin cycle
Failure of the water level sensor
Oct 10, 2017 | Fisher Paykel EcoSmart GWL15
Whirlpool Washing Machine Leaking At top During Spin Cycle
Is it possible that the water level is too high. This can be caused by the sensor that controls the amount of water. The control knob that says small low medium large does it work if you put our small setting is the water stopped early like it is supposed to. If the water level is too high during spin cycle it is possible to run up and over the side. Let me know Ed
Nov 28, 2011 | Whirlpool Washing Machines
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED...
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
Can't see water leverage
water level needs to be brought up alittle on your amount of level as in small med large loads...
Jun 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Feb 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water level adjustment
You don't. Front load washers use only a very small amount of water. They fill a small amount, tumble a bit, resulting in water being absorbed into the clothes, which drops the water level in the tub. The washer senses this and adds more water, which repeats until water level stabilizes. The only way to get more water on wash cycles is to use delicate cycles, which use more water, resulting in a more gentle wash action. Remember that due to the low water consumption of front load washers, you should only use one tablespoon of HE detergent per cycle. (even less if you use 2x or 3x concentrate.) This is a FixYa solution. Your washer is working as designed.
Oct 23, 2008 | Whirlpool GHW9100L Front Load Washer
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Oct 01, 2008 | LG WM-2277HW Front Load Washer
How to increase water level in my frontload
The water level is not user adjustable but if there is a problem then the analog pressure switch should be changed.
Mar 09, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
