Question about Poulan 14" Chainsaw
What is the gap supposed to be for the ignition module?
What is the gap set for a 1800 woodsman 1.8cc
Posted on Aug 11, 2010
455 Rancher. What is coil gap?
Adjust the gap between the ignition module and magnet to 0.3 +/- 0.1 mm. The gap must be measured at either of the two lowest pegs
on the ignition module. Tighten the bolts to 4.5-6
Nm.
Feb 23, 2016 | Husqvarna Garden
Fs55r What is the Ignition module gap setting
Hi...
I have replaced a number of Ignition Modules in chain saws, lawn mowers, etc. and the one trick that solved the problem of setting the Gap Setting, was to use a "Business Card" in between the Ignition Module and the Flywheel. Just curve the Business Card around the Flywheel magnets, and press the Ignition Module firmly against Business Card and tighten down the holding screws. Then pull the Business Card out, and the Gap Setting is perfectly set. Easy and it works every time.
Rayko
Aug 21, 2014 | Garden
5200 no spark
Remove the left side cover to expose the flywheel and ignition module. Set the module pole gap by turning the flywheel magnets under the module, insert a thin business card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps do not close up at any point. Remove the ignition switch wire from the coil connection (not the pole ground), and install a fresh spark plug gapped at 0.020". Try again for spark. If nothing, replace the module. Hope this helps!
Nov 25, 2010 | Poulan Garden
I cannot start the blower/vacuum after replacing the ignition module.
You need to use a thin business card to set the pole gap at the module--access the flywheel/module area again and turn the flywheel magnets under the module poles. Insert a thin business card into the pole gaps, loosen the module mounting screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Rotate the flywheel one full turn to make sure the gaps don't close up any further. Remove the ignition switch wire from the module body for a test, and try for spark--it should be blue and snappy on a clean plug gapped at 0.020". Hook the ignition switch wire back to the module. Hope this helps!
Nov 24, 2010 | Garden
HUSQVARNA 1998 365 CHAINSAW WON'T START. PLUG WON'T FIRE.
I assume that you have already tried a new plug (gapped 0.020") with no results. Remove the left case cover to expose the flywheel and ignition module. Remove the ignition switch wire from the module (not the one tied to the module metal frame), and try for spark again. Check the module pole gap with the flywheel magnets just under the module poles using a thin business card for a gap gauge. Insert the card and loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gap doesn't close up. Test for spark again--if still nothing, replace the module using the same gap method. Hope this helps!
Nov 03, 2010 | Garden
How do I remove the ignition module in a 2300cva chinsaw?
Remove the starter mechanism and the left side cover to expose the flywheel and ignition module. If you have little or no spark, try setting the pole gap using a thin business card for a gap gauge. Turn the flywheel magnets under the ignition module poles, insert the card into the gaps, loosen the module screws and allow the poles to contact the magnets. Reset the screws and try for spark. Hope this helps!
Sep 07, 2010 | Poulan Garden
No spark form high tention wire chain saw will not start
Try a fresh plug gapped at 0.020". If no help, remove the cover from the flywheel side of the engine so that the flywheel and ignition module are exposed. Remove the ignition switch wire from the module and try for spark again. If nothing, then check the gap between the flywheel magnets and the module poles with a thin business card--insert the card into the gap and allow the module to snap to the magnets when the screws are loosened and then tightened. Rotate the flywheel somewhat to work out the card. Recheck for spark again--if still nothing, replace the ignition module using the same procedure as above for installation (don't forget the ignition switch wire). Hope this helps!
Jul 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Air gap setting
I assume you are speaking of the ignition module pole gap to the flywheel. Rotate the flywheel magnets under the ignition module poles, and use a thin business card for a gauge. With the card in place, loosen the module screws and allow it to contact the magnets, then re-tighten the screws. Rotate the flywheel to remove the card, then turn the flywheel one full turn to make sure the gap does not close up at any point. Don't forget the ignition switch wire. Hope this helps!
Jul 06, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 295 model chainsaw/ won't start, no spark
Start first with a fresh spark plug set at 0.020" gap. Make sure ignition switch is on. If still nothing, remove the cover from the flywheel. Set the ignition module gap by using a thin business card between the module poles and the flywheel magnets. Loosen the mounting screws, let the module contact the magnets, and re-tighten the screws. Turn the flywheel to remove the card, then rotate the flywheel on full turn checking that the gap doesn't close-up any further. Check for spark again--if still nothing, remove the ignition switch wire from the ignition module. Check for spark--if spark now occurs, check the condition of the ignition switch or the connecting wire may be grounding out somewhere in between. If still nothing, replace the ignition module. Hope this helps!
Jun 10, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 14" Chainsaw Logo
111 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
