I have a Saisho SX26G1 lcd tv and the picture scrolls to the left and the colours change. I think it has something to do with the RGB scart connecter at the back but I'm not sure! Can you help please?
  • 4,889 Answers
Does this happen on all inputs like HDMI, Component etc., and on all input sources like DVD, cable?
Posted on Jul 11, 2010
  • 2 more comments
  • darrencl2001 Jul 11, 2010
    Hi, it's not an hd tv, but when I watch cable tv it is suggested that it should be plugged into the RGB scart connector on the back of the tv.
    I have done that and the picture seems to scroll tto the left and the colours get messed up. Please help?
  • eagle338
    eagle338 Jul 11, 2010
    And the scart comes from a cable box I suppose? Does it have a Yellow, white, red output?
    Yes it does, however only via jack plugs.
    So I have plugged the scart lead from the tv out socket on the cable box and plugged the other end of the scart lead into the RGB scart socket on the back of the tv.
    I have tried various av channels on the tv such as S-VIDEO (where the picture only comes out in black and white and is quite grainy) CVBS and RGB.
    In the last two cases the picture scrolls from right to left and the colour is at opposites.
    For example anything that should be red, comes out green and vice versa. And skin tones are comimg out blue!!!
    Any clues?
  • eagle338
    Scart input is know for problems. I suggest you get a RCA cable(Yellow, white, red) and hook it up. That should do the trick. Not only that the video quality will improve significantly. Give it a shot and let me know.
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
Sep 13, 2011 | Televison & Video
I have a Toshiba 3387DB TV and am trying to connect it to my laptop. Tried to use DVI (out of laptop) to RGB phonos cable. Then through a scart adapter into the Scart 1 socket at back of TV. Manual says...
You need to convert the component sync signals into a composite sync compatible with SCART. The red, green and blue signals can be connected through as-is.
Mar 21, 2011 | Toshiba 3387DB TV
The picture is blue when I play a dvd. I recently connected it to a new Vizio TV. The other tv it was connected to gave us a good picture.
Check your connections for faults, also some connections on TV's are for RGB inputs, so you might have to try another connector or if you can switch the DVD's output to RGB etc.
Apr 04, 2010 | GoVideo DVR4000 DVD Player/VCR
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Im trying to tune in my old super nintendo my lcd tv that has built in freeveiw but i cant find the channel!
Has your freeview tv got a built in RF i.e (not a digital freeview) tuner? If it hasnt then you wont be able to tune it into your LCD TV by connecting it through your aerial socket. However I think you can get a cable so that you can plug the nintendo directly into a scart or rgb input. Something like this.
http://www.consoleplus.co.uk/product_info.php?pName=av-cable-for-gamecuben64-and-snes&osCsid=0d6106987e4b7a95fc32bf0d45a3b6d1
Then you can just switch to your scart or rgb source on your telly and play on your snes.
Rob
Nov 27, 2008 | Televison & Video
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
I have a scart(out) to rgb phono 3 plus 2 audio when I connect I get a message ;Mode not supported&; I am trying to free up a scart socket on my tv and also improve my picture.
Hi.
I think you are A little confused.
The 5 phono connections are for component this is not compatible with scart.
You may be able to use A svhs lead if your tv & item you wish to connect have svhs sockets & then usu red & white phono for the audio.
http://dysonmanuals.llc.nu/
Mar 20, 2008 | Televison & Video
Denon 1508 A/V receiver; sound but no picture
I would try direct connection using a short SCART lead with full 21 way cable.
Feb 22, 2008 | Audio Players & Recorders
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Lcd TV display is dark
Ask the same question on a more useful website....
Nov 17, 2007 | Televison & Video
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
