Question about Dometic NDR 1062 Refrigerator
My Dometic NDR1062 only runs on gas, its set for auto and has 110
My NDR 1062 Dometic fridge only runs on gas, its set for auto & their is 110v at the plug, bad board? is their another fuse outside?
  • Dometic Master
  • 3,361 Answers
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
Posted on Jul 11, 2010
Does not cool on either ac or gas. there is green fluid to right of coils undera 1 ft cyliner tube.
Your cooling unit has leaked, the green fluid you see is the ammonia solution. We are Arcticold Refrigeration. Our NEW replacemnt cooling units come standard with new installation hardware, installation instructions, and a lifetime warranty. Our products are a cost effective solution to buying a new fridge and our units outperform the factory installed units. Our Units are "Built tough to last a Lifetime"Give us a call 1888-782-6665 ArctiCold Refrigeration We keep it cold I have attached a pic bellow of an Arcticold built NDR1062 cooling unit. c9cd0543-0253-4ec8-b002-2cece05f86e6.jpg 3e135613-2b82-4462-bd42-72e04ed7e14f.jpg
Feb 16, 2014 | Dometic NDR 1062 Refrigerator
NDR 1062 Dometic Refrigerator
Not unless you unplug the thermistor from the circuit board and let it run for 24 hours. If it does not cool after that then your cooling unit is bad.
Dec 05, 2013 | Dometic NDR 1062 Refrigerator
No power to front of control panel. Checked all fuses in back and no 110 electric
check all gfci resets and if plugged in check convertor voltage if below 10 volts will not run fridge panel runs off of 12 volts check fuses in front by tongue jack
Aug 01, 2013 | Dometic NDR 1062 Refrigerator
Prroblem with rv gas refrigerator Dometic ndr1062
I assume you've checked baffle distance above flame? Anything changed above fridge, as in clearance, ventilation above etc. Maybe even removed a piece of panel, that was used above fridge for vent deflection etc?
Jun 25, 2010 | Dometic NDR 1062 Refrigerator
I have a Dometic RV refrigerator Model # NDR1062 and it works with the electric power with the generator on (not on battery)but will not work on gas. The gas unit clicks like it wants to start but will not...
My best guess without seeing it is you are not getting gas to the unit
Break the gas supply line at the gas valve with the LP turned on and see if you are getting LP gas
Without the proper water column inch meter it is impossible to tell if you are getting the right pressure, but if your stove top, heater and water heater work then I sill guess you have rubber hoses feeding your refer. Propane and rubber build an oil that will over time plug the supply line and not allow LP to reach the refer. They have to be cleaned out and it is a messy job
Dec 19, 2009 | Dometic NDR 1062 Refrigerator
Not cooling on 120 V0lts
NDR 1062, cools with gas but will not switch over to Ac . If i turn off lp, check light comes on and doesn't cool
Jun 22, 2009 | Dometic NDR 1062 Refrigerator
Dometic NDR 1062 Interior Light Assy Fasteners
I finally did a Google search for the NDR 1062 and found the Illustrated parts breakdown on PPLs web site. Also, received an email from a helpful reader of Fix-Ya Site with another site that had the parts manual.
Apr 14, 2009 | Dometic NDR 1062 Refrigerator
Frdge freezing everything
Check to make sure the thermistor is attached to the fins on the inside of the fridge. Otherwise you may have a bad control cable assy.
Jan 12, 2009 | Dometic NDR 1062 Refrigerator
Dometic NDR 1062 Refrigerator Logo
234 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
