Question about Frigidaire Freezers
Upright freezer we have just purchased an upright freezer it is great but we hear a sound like a vapor lock or suction noise when we close the door not to sure if this is normal
  • Anonymous Mar 30, 2014
    door will not open
Just asked a question not needing to pay 10 .00 dollars for the answer can call frigidaire for fee
Posted on Apr 20, 2008
Kenmore upright freezer not freezing
Kenmore & Whirlpool refrigerator frost build up in freezer not ...
? 7:02
www.youtube.com/watch?v=gVXT7pZyk_o
Sep 12, 2013 - Uploaded by ApplianceVideo.com Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
Freezer Troubleshooting - What to Check Before You Call a ...
www.realestate.com > Realestate.com Blog > Articles
Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
Sep 19, 2015 | Kenmore Freezers
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | Whirlpool Freezers
We have an upright Commercial Grade heavy duty Imperial Freezer, model # UL4000ECW2, purchased a little over 10 years ago. Today I noticed that everything in it is thawing and when I close it, it no longer...
the suction noise is not something that will happen all the time.
check the current draw on the compressor and make sure it is in between 1.2 and 1.6 amps.also look at you evaporator coils and make sure there is no excessive frost build up.If there is ice build up then you need to defrost it check the heating element and defrost timer and make sure they are in proper working order.also check the evaporator fan and make sure it is working when the unit is in a cooling mode.
Sep 07, 2010 | Freezers
Door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Jan 28, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
Freezer has lost its suction & no longer freezing!
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Jun 21, 2009 | GE 17.1 cu. ft. / 484 liter Upright...
Bubbling sound coming from the bottom of my freezer
There is a vacuum build up in the freezer compartment when you close the door. This can make the door difficult to open. You can overcome this by sticking a small lollipop stick to the bottom part of the door gasket. This will act as a vacuum breaker.
Mar 06, 2009 | Whirlpool Upright Freezer EV161NZRQ
Door
If the door is not sealing because of frost build up or product blocking it it won't make the noise. Is it still cooling ok? If you haven't defrosted it you might do this now. Is it in a cold location, i.e. unheated garage up north? This can cause it also. Check the door and the cooling first if it's not right I would call for service. You should have a one year warrany.
Apr 01, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
141 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
