Question about HP Computers & Internet
I have an HP540 but my sound audio icon has disappeared. What do i do to get it back please?
  • 621 Answers
In control panel under sounds you will see an option in there to show icon on desktop. If its already ticked untick it and tick again then apply ok.
Posted on Jul 11, 2010
The sound icon has disappeared from the task bar. I've checked control panel (sounds and audio devices) and the 'place volume icon on task bar' has gone grey and can't be ticked (it was ticked before icon...
hello from a few days ago I was working on my laptop and suddenly reboot. but now get a message that is:
sis UNDI, PXE-2.1
copyright PXE BootROM v1.09f - ZL5_0324 Use BEV/BBS
=== Press <Esc> to bypass LAN check. ====
him and tried to boot from the CD drive. order to retrieve information or other cases formatting. but when the process goes to the information is not in the hard disk.
Aug 17, 2013 | Dell Inspiron 1501 Laptop
The sound icon on my HP laptop disappeared
If the sound is muted go into the Volume control and uncheck the Mute box.
If this does not work then reinstall the audio driver.
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 17, 2013 | HP Computers & Internet
How can i get my Volume Icon back into my Task Bar? My (3yr) old daughter has been 'playing' with my Laptop and now my Volume Icon disappeared and i can't seem to figure out how to get it back and working!...
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Dec 05, 2010 | Microsoft Windows Vista Ultimate Edition
My audio icon disappeared. How do I restore it? The computer is telling me "no audio devic found."
Please enable your sound device from BIOS and check it.If still issue not resolve then reinstall sound driver and check it.
Oct 06, 2010 | Computers & Internet
No audio with videos
When playing videos in YouTube and has no sound maybe the cause of the following errors:
  1. The volume control of the video itself is in mute mode, to solve this problem refer to the YouTube video controls, particularly the volume button.
  2. The volume control of the headset or speaker is in the low mode, to solve that problem check the volume control of the speaker or the headset.
  3. The volume control in the computer task-bar sound icon is in mute mode, when the icon has "x" means the sound is not working, to solve that problem click the icon and remove the check in the small boxes at the bottom that causes the disappearance of sound.
  4. The computer has no installed audio devices although you have the audio hardwares, I am referring to compatible audio drivers in order to work the device, to solve it please check your devices in My Computer>>Manage>>Devices. When there are exclamatory sign to some devices that maybe the sounds, so better look for compatible drivers in order for it to work.
  5. The sound cord maybe plugged in a wrong socket, to solve it please observe the color coding or refer to the manual. And if doesn't work in front panel please do it in a back panel. To ensure that the front panel is working you should open the case and look for that little power cords that have to be connected to the motherboard.
  6. The hardware might have no power especially speakers because they require power to work so better check the power cord if it is connected.
  7. If the foregoing are not helpful please ask the technical support of your supplier.
Sep 04, 2010 | YouTube Videos
Speaker icon disappeared and now i have no sound
Go to control panel, -> sound -> sound and audio devices ->sound and audio device properties -> check the first tab for, "place the icon on the task bar".
Dec 05, 2009 | Toshiba Satellite A65-S1362 Notebook
Laptop HP540 , sound problem- dis appear
the speakers on the computer might have gone bad so connect external speakers> if they work then the internal speakers have gone bad>
or else go to the Control panel> select sound> see if speakers are the Default device or not> if not select so
Jun 26, 2009 | HP Computers & Internet
There is no sound in my HP540 Laptop after formatting.
Hi!
You need to install the Conexant Audio Driver , download and install the driver below and you will be fine.
sp35940.exe, (1/1 , 5.47M) Good luck Nic
Mar 30, 2009 | HP Computers & Internet
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Sound Card Problem
click on start go to control panel
click on sound and audio devices
make sure that the mute option does not have a check mark next to it
and put a check mark in the box which says place volume icon in taskbar
click on apply
then ok
then check if you get a volume icon and do check the sound
Jun 03, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
