Question about Kenmore Ovens
Cuisiniere Kenmore model# c880634839g2 indique le
Cuisiniere Kenmore model# c880634839g2 indique le code d'erreur E1 -F 1-. que puis je faire pour regler le probleme? merci
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F1-E1 error indicates that the control board has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
Kenmore wall oven fault code f61 what does it mean when it says this fault code
Find the model number. See which oem manufacturer built it using the information at
Sears Kenmore Fault Codes AppliancePartsPros com
and then look up the code under that manufacturer.
Feb 17, 2017 | Kenmore Ovens
We have a GE Profile cooktop in the house we bought. I found the manual from previous owners of house and it is a JP350. It has white knobs (4 large and one smaller one). I would really like to have...
Bonjour, j'ai un four GE Profile électrique acheté en 2006 et lorsque je veux me servir du fourneau, tous les boutons digitaux sur lesquels j'appuie donne comme résultat "LOC On". La plaque fonctionne toujours bien c'est seulement pour la programmation du four que j'ai un problème. Est-ce qu'il se peut que j'ai appuyé par mégarde sur quelque chose qui verrouille les commandes car jusqu'à dimanche dernier il fonctionnait bien? Comment régler ce problème? Merci à l'avance
Nov 05, 2010 | GE Ovens
The oven will unexpectedly shut off during use. The code "F-3" will display.
Probably the oven sensor. Fairly easy to replace yourself. Good Luck.
Aug 17, 2009 | Kenmore Ovens
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE lower oven displaying code F8. Clear off does not clear code
Your ERC(clock) has failed. Replace the electronic oven control.
May 26, 2009 | GE JRP15 Electric Single Oven
F2 code on a oven mod#911-41069690
go to repairclinic.com click on repair help, then error codes... scroll to kenmore (it will give you a list by the first 3 digits of model number, who really made the machine.. (kenmore doesn't make anything) then go to appropriate brand and find error codes.
Feb 25, 2009 | Kenmore Ovens
My kenmore oven/stove is showing F4 what is this
F4 indicates the oven temperature sensor is bad. Not knowing the exact model you have I can't give you an exact price but I've always used http://www.appliance-parts-warehouse.com/ for my parts but you're free to shop elsewhere if you plan to make the repair yourself. The part isn't very expensive and is fairly easy to install yourself.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Jun 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
419 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
