Question about Hardware & Accessories
I need programming instructions for a Timex Model TE103/1(12/871)5A solid state Appliance Controller (solid state timer)
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: manual for appliance control TE103/1
You can get the manual on the link below.
http://waterheatertimer.org/pdf/Timex-T103.pdf
Posted on Oct 20, 2011
SOURCE: lost instructions for TE109 appliance timex
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Posted on Jul 23, 2011
How to program a dynascan Model 485 night sentry solid state timer
Try Googling (dynascan)(485)(manual) without parens for programming instructions.
May 15, 2018 | Hardware & Accessories
Need instructions to program a timex indoor timer model #tm120wp
turn on your tablet connect any keyboard.then use keyboard.go to setting and reset it.its very simple solution.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 14, 2012 | Timex Indoor Timer Multi Setting...
How to use the TM 111D
1) To use the timer:
Make sure outlet has power.
Check outlet with circuit analyzer to make sure polarity issues do not affect timer operation.
Plug timer into outlet for 1 hour until battery is charged.
Some timers have internal battery that do not need to be charged.
After battery is charged, unplug timer to set programs.
Set program(s).
Turn lamp ON and make sure bulb is good.
Leave lamp turned ON
Plug lamp into timer.
Then plug timer into outlet.
2) To program the timer, open following links for possible instruction manuals:
http://waterheatertimer.org/pdf/How-to-program-Timex-TE111.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Timex EASY TO SET TIMER BY TIMEX
I purchased a 1875 watts Timex Heavy Duty timer Model # 12-881 to connect to my 1200 watt water distiller. The timer is burned and has melted where the distiller was plugged in. We were furtunate...
Timex 12-881 timer has 3-prong outlet and is rated 15amp 1875 watts.
The timer melted because too much amperage was drawn across the connection and timer got hot.
Different things can cause this.
Phony rating, and/or mis-manufactured timer.
Defective timer.
If distiller has a motor, then it will draw more amps at start-up.
Timer is rated for incandescent light bulbs only.
Many timers say 1875 watts resistive, but instruction sheet will show 1000Watts incandescent and 1/4 HP horsepower.
Timer is plugged into extension cord.
Cheaply built product, not meant for constant use.
Timer outlet and distiller plug did not meet firmly, so connection heated up.
Turn off distiller before plugging into outlet so no spark is at the connection point.
I recommend appliance timer for operating appliances.
For example Intermatic HB 113 timer.
http://www.smarthome.com/25071/Intermatic-HB113C-120V-20A-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Also heavy duty portable timer like Intermatic P1121
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Sep 01, 2011 | Timex Heavy Duty Appliance Timer
I have a model #Te111(TX12677T), I am having a problem with programming this Timex light timer. I can get the time on, however when I try to program each day it will not hold it's memory. Help ...
Open following link to identify timer and download manual:
If the manual does not match product, then add a comment with clear description of timer and what you have done so far to set timer so I can see problem clearly.
If timer will not hold programming, then try resetting timer if it has a reset button.
If timer has battery, remove battery and replace with new battery, and try resetting timer in that manner.
If functionality is not restored, then move timer to different outlet and connect to different lamp.
And always test outlet with cheap circuit analyzer from home center.
Outlets that are out of code can affect electronics including timers.
If outlet checks out, then timer is probably defective.
Most timers have 1 year limited warranty.
Intermatic DT620 has limited lifetime warranty and might be better value long-term
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Woods 59377 is nice timer sold under different brand names at Lowes, Target, on-line:
http://www.amazon.com/Woods-59377-Digital-Appliance-Settings/dp/B000IKQRTU/ref=pd_sim_dbs_k_1
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Jul 26, 2011 | Hardware & Accessories
I can not reset my Timex timer . The timer stopped working after a month and the instructions to not help in programing these timers
The instructions will help quite a lot right now:
1) Typical Timex manual says to re-set timer, press MODE and PROG buttons together.
Compare this information with your instructions.
2) Look on instruction sheet for timer model number, and then add a comment with your model number so I can identify timer manual and possibly post answer that fits your product.
3) Look on instruction sheet for company information.
Timex timers come with standard 1 year limited warranty:
Following phone might work: 1-800-919-3101
4) Scan your instruction sheet into jpg format and then add a comment with link to that jpg, then I can give you best answer for that specific timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
5) Buy another timer, and return broken timer in new package.
6) Use circuit analyzer to test outlet for line noise and ground fault that affect timer electronics.
7) Buy another brand of timer altogether:
http://waterheatertimer.org/GE-timers-and-manuals.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 31, 2011 | Timex EASY TO SET TIMER BY TIMEX
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
Dec 17, 2010 | Timex Hardware & Accessories
Hardware & Accessories Logo
681 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
