Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Motherboard drive i have problem with my motherboard
  • HTS Sri Aman
    HTS Sri Aman Jul 19, 2010
    what your motherboard problems?
    Problem Solver:
  • 5 Answers
What exactly is the problem?
1. System not booting?
2. Drivers missing?
3. Hardware malfunction.
Posted on Jul 26, 2010
I have no local c drive how can i reinstall
Either:
* the existing disk-drive is not connected (power, data) to the motherboard;
* the existing disk-drive is "dead";
* there is no disk-drive at all inside the case;
* the motherboard has been told to "ignore" the device.
So, either:
* connect (power, data) the disk-drive to the motherboard;
* remove the existing "dead" drive, and install a new one;
* buy a new disk-drive, and install it;
* enter the motherboard's "BIOS SETUP" mode,
and use the "auto-detect disk drive" tool to "add" the drive.
Oct 15, 2010 | Dell Computer Refurbished DUAL PROCESSOR...
Need location of HDD ATA connectors and jumpers on motherboard
You need to look at the motherboard to find the pins that fit the hard drive ribbon cable. Then plug your cable into the motherboard and the hard drive. Nowadays, motherboards do not have jumpers for hard drive function.
If you have a really new motherboard, you may not nave any ATA connectors at all. New motherboards are going to SATA.
Sep 12, 2010 | Computers & Internet
How much hard capacity is suportable to intel 8280 motherboard
Are you asking how large a hard Drive the 8280 chip set will support? Every time I searched for 8280 motherboard it shows as a chip set used in some boards not as a motherboard model for any Intel product. Hard drive size is not like RAM. If your Bios will support the Hard Drive and your operating System support the Drive the Motherboard can handle it in all cases I've ever run into. Even a few years back with Bios restricted the largest hard drive you could install manufactures developed a software solution that was installed on the hard drives so they could be used. If this doesn't help please verify your motherboard model and clarify what you are looking for.
Aug 07, 2010 | Intel Desktop Board D875PBZ (BOXD875PBZLK)...
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
Cold boot no HD warm boot it sees the hard drive
Usually that is drive related not the motherboard. The drive may be slow to boot and the motherboard times out waiting for it. By the time you reboot the drive is running or spun up enough to get past this.
To confirm you can try the drive in a differant computer as a secondary and then run scans and any stress test software. You may find the drive is failing or about to.
Apr 24, 2010 | ASUS P4V8X-MX Motherboard
Pc is saying hard drive not found
New PC or old PC?
New motherboard or old motherboard?
New hard-drive or old hard-drive?
Check the ribbon-cable between the motherboard and the disk-drive, to make sure that both ends are seated correctly.
Turn the computer off. Unplug the AC power-cord.
Touch the hard-drive -- is it "warm" or "cold" ?
Cold means that it is not getting any power.
Remove the hard-drive. Look at the labels on it. Write-down the manufacturer, model-number, serial-number, and manufacture-date. Go to the manufacturer's web-site, and enter the serial-number, to see if the drive is still under warranty.
Oct 10, 2009 | Intel D850MV Motherboard
Drive not ready
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
qpttttt20
Apr 06, 2009 | Intel DG31PR Motherboard
New hard drive not reconized, motherboard drivers
I had this problem on a computer recently. This particular motherboard may be needing the driver on the Windows XP SP2 disk. Your motherboard may have been made to use Microsoft SATA drivers. Othewise, there would have been a driver disk that came with the motherboard to let it see that SATA hard drive.
If it's a new hard drive, you have to reinstall the O/S so use a disk new enough to have SP2 included.
Jan 17, 2009 | Biostar K8VGA-M Motherboard
Motherboard accepting sata cords for hard drives
I'm afraid that this board does not support SATA drives.
Hi - You can download the manual from the link underlined in blue below:
8VM533M-RZ
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 25, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
