Question about Radio Shack Pro-95 Handheld Scanner
I have a Pro-95 scanner that I enjoy alot, the problem is that the keypad seems to be locked, sound and squelch work fine but not a single button, I've tried the reset button several times. Any help would be greatly appreciated.
  • 99 Answers
Look at the keyboard and find the button the shows the symbol for a key and a symbol for a light bulb. Press the FUNC button and then the key indicated above. The words key unlocked should appear in the display. Repeat the process to lock the keys again.
Posted on Aug 31, 2010
  • kirbdog37 Nov 20, 2010
    key button doesn't work either, just the sound and squelch
Getting scanner to scan
Make sure that the keypad isn't locked. See if there is a little key in the display. If yes, then hold down the lock key to unlock the keypad. Next, hit 'scan' and you will have to select a group to scan, so press the #1 or #2 button IF you have frequencies loaded into it. Can you press the WX button to hear the weather? Let me know. Good luck.
Apr 20, 2014 | Radio Shack Pro-95 Handheld Scanner
Pro 95 scanner squelch does not silence receiver regardless of knob position,subsequently receiver will not scan.
Your squelch control may be back or your control needs to be aligned properly on the circuit board. Ship it in for repair if you wish. dodgem250.com
Mar 31, 2010 | Radio Shack Pro-95 Handheld Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Squelch quit working in regular scan mode PRO-528
Just fixed my squelch problem; I don't know how it happened but Resistor 138 was burned & intermittant. It was so badly burned that I could not read the color code but it measured 880 ohms intermittantly. I replaced it with an 860 ohm carbon resistor & all seems well; time will tell. R-138 is located on the circuit board right behind the squelch potentiometer. R-139 is immediately behind the pot & R-138 is next to R-139. All I had to do is remove the 4 screws on the back of the case & the unit splits in half. I clipped the old resistor out leaving a bit of the old leads so I could solder in the new resistor without having to get to the backside of the circuit board. Scanner is working as I type this & I hope it does not burn out again. Hopefully this is the same problem in your scanner & an easy fix. Good luck.
Bob Tomlin
WB1AIJ
Dec 11, 2008 | Radio Shack Pro-95 Handheld Scanner
NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Not scanning
Assuming that the squelch operates, the problem lies in a circuit that interfaces the squelch & scanning circuits. Probably not worth the cost of repair.
May 13, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio shack pro97
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Feb 24, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
123 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
