Question about Samsung SyncMaster 913N 19" LCD Monitor
I have a problem with my Samsung 913N monitor.
I have a problem with my Samsung 913N monitor. After a short period of not using the monitor it becomes black and I can not start it up again. One of the solutions is to fix a resistance inside. My problem is that I do not know how to open the monitor. Can somebody explain this to me (pictures will also help).
reegards,
Hans
  • 11,361 Answers
Service manual: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=913&kategoria=monitor&kat2=all
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 11, 2010
Monitor switches on ok, but; after a short period; switches off.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 17, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Screen remains black only after starting
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Problema com o monitor samsung syncmaster 913N 19"
fix is easy just solder a 47 ohm resistor between pins 5 and 6 in the main transistor
Sep 06, 2008 | Samsung SyncMaster 913N 19" LCD Monitor
Sasung 913n monitor
Same here. The unplug/inplug of the monitor seems to be the workaround. For now, I boot up Windows with the 913 unplugged and connect it after a couple of minutes when Windows has booted up. As mentioned before, this bug only happened to me after shifting to a PCIe card, Nvidia 6600 LE driver.
Dec 29, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung 913n
can anyone tell me were i can download drivers for samsung 913n monitor please thanx carlos
Dec 17, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung SyncMaster 913N 19" LCD Monitor Logo
300 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
