Question about Samsung NC10-14GW PC Notebook
My display has turned to the side as if am reading a book and i cant fix it
    Scholar:
  • 58 Answers
If the above didn't solve your problem - which it doesn't on my Samsung NC10... Go to Start - Control Panel locate the Intel GMA Driver for Mobile - (double click it to open it).
On the left side you'll see Display settings - click on that - on the RIGHT, now you should see Rotation. First, click on the TOP (0) degrees and then Untick 'Enable rotation' rotation.
Your screen should have reverted back to normal.
Posted on Aug 05, 2010
  • Samsung Master
  • 32,281 Answers
An upside down display is caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Posted on Jul 11, 2010
Radiator fans not working 2005 dodge caravan (voyager) Unplug coolant temperature sensor and with the key on the the fans run. Is the temperature sensor malfuntion?
the fans come on only at the spec, temperatures!
unplugging the ECT causes the PCM to see the ECT is dead.
(total death = cant see temps)
and a dead ECT means the PCM cant know temperature
so the PCM turned on the fans to protect the engine from damage.
so why not learn how to test fans the correct way, by reading the FSM , it tells you how on all cars made.
the FSM is the factory service manual.
if car has A/C it has up to 3 rules for engine side fan.
or more.... all in the book
1: engine overheated, stage 1 or 2. (all will trip idle until too hot) that is the test.
2: A/C on and or above. or mix of rules a/c and overheated.
3: it may also kill A/C if engine overheats.
if not wanting to buy and FSM. the read alldata.com
under engine cooling, its all there. just read away.
The PCM does not run fans just for fun.
ever.
they can also turn on parked, while shopping on some cars.
do to overheated while soaked. this protects the system.
but all that is in the book too. (complex and more so each newer year.... so that is why reading the book matters to track with evolution)
Jun 24, 2015 | 2005 Chrysler Voyager 3.3
How do I delete a book once I have read it from the nexus 7
What App are you using? Kindle or Play Books? I'm not sure about Kindle but in Play Books you tap on the books settings and select "Delete from Library". The settings tab is a line of three vertical dots on the lower right side of the books icon.
Hope this helps.
Sep 14, 2014 | Google Nexus 7
Why cant i use my kindle when pluged into my computer, am i thick
When you connect your Kindle to a PC, it automatically goes to USB mode, allowing access to its internal memory from the PC. The Kindle cannot display a book for reading at the same time. It would require quite complicated handling, for example, to display a book while the book is deleted by the PC concurrently. Allowing only one machine access to the internal memory at a time avoids any concurrency issues.
If you want to read books while continue charging, on the PC:
  • Windows XP, Windows Vista: find the "Safely Remove Hardware" button in the status bar (right side of the task bar), and select "Eject" for the Kindle device.
  • Windows 7: Open "My Computer", press the right mouse button on the drive icon representing your Kindle's internal memory and select "Eject".
Jan 02, 2011 | Amazon Kindle Wireless Reading Device
All the words on my reader have turned sideways so i cant read it the right way anymore what do i do to fix this?
First, check whether this issue occurrs with all the books. If it happens with only one book, redownload the book again. If the issue happens with all the book, perform a soft reset. To soft reset, press the RESET button using a sharp-pointed object. That should reslve the issue. But, unfortunately if the issue still persists, perform a hard reset. But remember performing the hard reset will delete all the books. Follow the steps listed on the page to perform the hard reset: http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1006378
If the issue still persists, service of the Reader may be required. Please follow the below link to get it repaired: http://eservice.sony.com
Dec 29, 2009 | Sony Reader Pocket PRS-300
Cant read/ see what am typing, cant see web contents
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Dec 25, 2009 | Nokia E51 Smartphone
Samsung digimax4010 memorycard locked cant take pictures
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Feb 26, 2009 | Samsung Digimax 4010 Digital Camera
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Samsung NC10-14GW  PC Notebook Logo
255 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
