Question about Car Audio & Video
I need to know where the rcas go and what wires go
I need to know where the wires go and what wires go in the back of the plug
    Guru:
  • 632 Answers
Red = To battery Black = Earth - Most people wire it to body of car Blue = REM Wire - Remote amp Wire goes to back of stereo so it can trigger amp to turn on
Then AUX L And R IN goes to The stereos AUX out.
After that its done
Unhook your battery before preforming any stereo modifications and remove fuse in the RED amp Wire it will be a big fuse you cant miss it, Case any wire accidentally touch when fitting they don't short .
Posted on Jul 11, 2010
Radio works no power to amplifier 1992 ranger
The power goes to your amplifier straight from your battery into your amp so make sure that's good and there's a blue wire behind your radio should say remote you extend that wire to your amp and that tells it when to turn on and of course the rcAs from your radio to amp if it's a stock radio go buy a LOC cause it won't have rcas and to use a LOC well you have to take the speaker wires and hook them up to your rear speakers and then take the rcas from the loc and plug them in the amp but make sure the amp is grounded first
Jan 26, 2014 | Car Audio & Video
I have a Technics turntable Model: SL-BD22-KM, Ser.#: GF3Fc73813. The RCA and ground connection panel on the turntable has been jurked-out tearing the wires apart. I need to know which wires are soldered...
hi,
Here is the wiring of the turntable RCA plug ( RCA wire will have 4 connections like red and its outer wire then White and its outer wire.). connect these as follows.
For right channel
Red wire from the turntable to the red center wire of the RCA plug
Green wire from the turntable to the outer wire with red wire of the RCA plug
For left channel
White wire from the turntable to the white center wire of the RCA plug
Blue wire from the turntable to the outer wire with White wire of the RCA plug
OK
Oct 10, 2011 | Technics SL-BD22 Turntable
Where do i connect the single rca plug from my pioneer home theatre sytem
usually it will go into the white plug on the back. if one of the rcas is labeled signal or LFE this is the one to put it into. let me know if you need further assistance.
Jun 14, 2010 | Wharfedale PowerCube PC-12 Subwoofer
No sound coming from dual xdvd8183
if its the rca the dual has thin rcas then u need to switch the rcas with the regular wires. u can use a speaker wire to rca kit to resume back to normal
Apr 27, 2010 | Dual Electronics XDVD8183 Car DVD Player
Subwoofer out put there is 1 i have 2 rcas
Get RCA "Y" connector, radioshack, etc.
Or, plug your 1 RCA into the amp and wire to sub from amp
Oct 09, 2009 | XO Vision XOD1735 Car DVD Player
Car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
Hi i have a mtx 1501 d
If it does it with no RCAs plugged in, the speakers or wiring need to be checked.
If the speakers and wiring are OK, the amp may have shorted output transistors.
Apr 10, 2008 | MTX Thunder 1501D Car Audio Amplifier
Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Dec 22, 2007 | Car Audio & Video
Car Audio & Video Logo
172 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
