Question about Garmin nuvi 255W GPS Receiver
Can't get out of Kansas location --- can't locate satellites
I downloaded new maps and now my GPS won't get out of locating satellites mode --- has us in Kansas!!! Any suggestions?
  • 63 Answers
Have you taken it outside to see if it needs better skyview to get a lock. I also suggest force feeding it the firmware again. You can use Garmin Webupdater to update the unit. It would of updated when you did the map update install but a file may of been corrupted.
Posted on Jul 12, 2010
Can not acquiring sateilites,and always start in kansas.dDid reset,and a hard reset.Samething.
How long did you leave it out in full view of satellites? In some cases, when the unit is new, you might have to wait 20-30 minutes for it to get an initial connection and to download the location info, etc to the unit. The location reads Kansas because that's where Garmin's head office is located so this is the default location.
If this solution solves your problem, please come back and rate our answer to your problem. Thank you.
Dec 27, 2010 | GPS
No matter what address i input, it can find the location but when it start navigate, the map turns out a location in Kansas..i dnt know why is that..i input washington state address
You need to change the State. When you go to put in the address does it show the state as Kansas. If so press change state and change it to Washington.
Jul 19, 2010 | Garmin nuvi 260W GPS Receiver
Gps won,t move from last location
When you put in a new location how are you entering it? If you are using the "Where to?" menu then you will need to click on the "Map" button instead of GO when you find the point you are looking for, may it be an address or a Point of Interest. This will show the location on the map. If you want that to be your current location you must have the GPS turned off. Then on some units you will Have the option to set as your current location.
I hope this was some help.
Cheers
Jul 14, 2010 | Garmin StreetPilot C330 GPS Receiver
I turn it my Garmin and it will not come up with my location, it is coming up Kanas and Im in Cleveland
Are you outside with the unit? It was made in Kansas and has Olathe, Kansas as it's default starting point. However, when you take the unit outside and it gets a satellite signal, it should find where it is currently. If not, the GPS might be turned off (for indoor use). Turning the unit off for a few seconds and then on again outside should put it in the proper mode to receive satellite signals. Let me know if this helps.
Jan 19, 2010 | Garmin nuvi 1200 Car GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
You will have to leave the unit out in the open so it can 'see' the satellites. It might need from 20-30 minutes to acclimatize itself to the new location. It is set at Kansas because that's where the manufacturer is, so that is the last recorded satellite signal.
Apr 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't change location-appears as if still in Kansas despite downloads
You need to go outside and turn on the Garmin until it has acquired a satellite lock (15-20 minutes). Kansas is the default location (Garmin Headquarters). Once you have acquire satellites, the Garmin will remember the last position as the starting position when the power is turned off. You know you have acquire a satellite lock once "Ready to Navigate" appears on the top of the screen.
Jan 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 350 Problem
Take it outside and turn it on.  Within a couple of minutes it should locate the satellite and tell you where you are.
Oct 06, 2007 | Garmin nuvi 350 GPS Receiver
How to change home map on used Garmin i3 street pilot
Hello. Had the same problem and just solved it.
Do this.
Tools -> Manage My Data -> My Locations. Position to Home and then click Manage -> Change Location ..
Cheers.
Sep 15, 2007 | Garmin Map Source City Navigator
Locating satellite
Initialization time has been greatly reduced with newer system software upgrade for the Garmin GPSMAP 545s. Get your system software upgrade here.
I hope that helps.
Aug 30, 2007 | Garmin GPSMAP 545s GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
152 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
