Question about Timex 27191 Wristwatch
I can change the date to the right date but don't know how how to change the day its a day behind
  • 831 Answers
What kind of watch? Normally, you can move the dial one way to move the day, and the opposite direction for the date,
Posted on Jul 21, 2010
HELP I DON'T KNOW HOW TO SET THE TIME. All the
In my experience the letters rise counter-clockwise from the 4 o'clock position.
so, A would be at 4. B at 2. C at 10 and d at 7. Usually the A is a mode selector and B, C and D control the hands and day/date (if you have them) try press B to control day/date and C for changing time forward and D for changing time backwards - whichever is the shortest way.
If you have a 12/24 mode, make sure you are in the right zone is matched with the time and am/pm setting.
Jun 23, 2013 | Watches
Watch date changes between 1:45 am and 2:00 am
turn it 12 hours forwards or 12 hours backwards that will correct it to the right date change
Jan 12, 2013 | Watches
Day is wrong, while date is correct
The date and actual name of the day are set separately on most watches. When you are in the mode to change your date, play around with the buttons and try to find a way to toggle to the days so that you can change it to the correct date. What kind of watch is it and I may be able to help. If you still have your owners manual it should say right in there exactly how to do it. If not you can search for it online if you know what kind of watch you have.
Dec 20, 2011 | Watches
Don't know how to set the date except by winding the time dial repeatedly past 12 to get to present date--must be an easier way
I presume that you are winding the watch 24 hours to change the date.
You can shorten the time it takes to change the dates in the following manner:-
Wind the watch until the date changes, then turn it back until it passes 12 again and then turn it forward. Each time it passes 12 the date should increase by a day.
You may have to experiment to find how far past 12 in both directions to get the date to change.
May 12, 2011 | Baume Et Mercier Baume & Mercier Classima...
Hi, I just purchased an Invicta 4718 watch, and although I have the date set correctly, the DAY is wrong. Does anyone know how to change the day?
Pull crown out 1/2 way to fist click. Rotate one direction for date and the other direction for day. Should be clockwise (right) for day and counterclockwise (left) for date.
Oct 20, 2010 | Invicta 8937 Wrist Watch
The date adjusts at 1am. any solution? thanks
mcdevito75 here, That sounds about right, each watch is slightly different, some watches, have the date change at 10:30 PM and some at 11:00 PM, and if your Tag also has the month or day to change along with the date, this could account for the date changeing kind of late. I don"t think it"s anything to worry about.
Aug 13, 2010 | Tag Heuer Formula 1 Date Quartz Stainless...
How to set a month on seiko ska401
mcdevito75 here, The month you mean the date (number of the day in the month) your Seiko should show the day / date Here"s how.--- To change the day (Monday, Tues. etc) simply pull out the stem and turn the hands around until you reach the day, now push the stem in all the way, and gently slip your fingernail under the stem and gently lift the stem to it"s first notch or position, Seiko watches have a 2 position stem to make changeing the date, (number) easy so you don"t have to keep turning the hands around and around, with the stem out to it"s first notch or position simply turn the stem either toward you or away to change the date, (number) when done push the stem back in and your done.
Jun 23, 2010 | Watches
Changing the DAY on this analog watch.
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 | Watches
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Dec 03, 2007 | Watches
Timex 27191 Wristwatch Logo
362 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
