Question about Sharp AR-5320 Black and White Copier
The display shows H and 4 blinking - Sharp AR-5320 Black and White Copier
  • faridullahya Jul 11, 2010
    the display shows H and 4
    Problem Solver:
  • 11 Answers
You have a problem with the fusing unit call a service representative ...
Posted on Jul 13, 2010
My hp 17 inch m7 k211 dx will not turn on the power port light blinks 3 times. Help?
HP ENVY m7-k211dx Notebook PC?
those are called BIOS blink code errors.
take the battery out yet and try, batteries love to dye and short.
run on line AC power only that cure it?
only 1 year old , (or less) 1 is max. Aug 1015 RTM
the books on it are here.
https://support.hp.com/us-en/product/hp-envy-m7-k200-notebook-pc-series/7527539/model/7734388/manuals
with battery out, will the display even show BIOS messeages
see page 84 in the manual.
see this, ? quote:
To start Setup Utility (BIOS), follow these steps:
1.
Turn on or restart the computer, and then press
esc while the "Press the ESC key for Startup Menu"
message is displayed at the bottom of the screen.
2. Press f10 to enter Setup Utility (BIOS)
page 86 shows how to run BIOS base line Diagnostics.
that be next
page 4 in the service manual tells you the power light blink rules.
the lightening bolt LED binks , means no line power, and battery is now dead. is the power pack missing>? unpluged.
try a direct on connection to wall AC power known good?
the same light blinks i SLEEP mode.,
here is HP;s offical blinking (LED) lamp codes and cures.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01732674
Apr 04, 2017 | HP Computers & Internet
Tip
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
Thanks
on Dec 08, 2009 | Computers & Internet
My sony tv shuts off after 30 sec or so and blinks 4 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 12, 2016 | Sony KDL60EX700 60 in. TV
Sharp lcd tv.lc45gd4u no power red light blinking two times pauses then repeats
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Blinking codes to so many brand TVs are described in detail here.
Nov 12, 2012 | Televison & Video
Reset de computer after change oil
On most models. you depress the trip reset and hold it down then turn the keyswitch to 'on' position. continue to hold while you watch the display where your miles normally show. SHould show dashed lines that blink. Example: first you see 4 dashed lines that blink, then 3 blinking lines, then 2 then 1, then nothing. That should do it.
Nov 28, 2010 | 2006 BMW 3 Series
Alpine CDE-9874E how can i set clock plz help me thanks
1 Press TITLE repeatedly until the time is displayed.
For details, see "Displaying the Text" (page 15)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing
TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the "hour." Minutes will reset to 00. If the display shows over
"30" minutes when you do this, the time will advance one hour.
Sep 20, 2010 | Car Audio & Video
My RCA digital voice recorder (RP5120-A) has no recordings on memory but when trying to record it shows a "full" blinking message! help please....
1. Turn on the
player.
2. Press ERASE,
DELETE will fl ash
on the display.
3. Press and hold
REC for three
seconds, FORMAT
will fl ash on the
display.
4. Press and hold
ERASE, WAIT will show on
the display, formatting is in
process.
• After the formatting is
completed, the remain time
of the selected memory will
show on the display.
You may also format the player
when connected to a PC (by rightclicking
on the player's drive name
or letter and select "Format" from
the menu). Make sure you select
FAT or FAT16 as the fi le system.
May 28, 2010 | Audiovox RP5120 Digital Voice Recorder
Letters and numbers appear in the display
L6 SHOWS LASER PROBLEM MOTOR MAY BI SENSOR.AND L4 DRIVE PROBLEM MAIN MOTOR OR MAY BI ANY GEAR IN DRIVE.CHECK ALL GEARS .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Feb 19, 2009 | Sharp AR-5320 Black and White Copier
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Sharp AR-5320 Black and White Copier Logo
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
