Question about Canon CanoScan LiDE 70 Flatbed Scanner
My scanner says to make sure there is space on my target disk. I have scanned albums, but am ready to delete them. How do I do that on the target disk? It apparently doesn't effect the target disk when I delete the albums from My documents.
  • 4,281 Answers
For that go to settings of scanner software and find the location of stored scanning documents.
Then make sure on that driver free memory space.
Then if still same problem then change location of scannning save option then it will work fine.
If still same issue then go to controlk panel->add remove programs and un install scanner software then reinstall it in different drive.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 11, 2010
Canon 7090C is slow between pages
If the target storage area is insufficient this will happen. Clear disk space, run 'defrag' to make space contiguous and try.
Also if you choose 24 bit color in TIF mode, it will take time to write onto disk leading to stopping in between scans.
S. Mohan, India
Apr 15, 2013 | Canon Dr 7090c Doc Scanner
Can not scan. Get message "Unable to scan. Make sure there is enough space on target disk". Changed default temporary disk location, have plenty of disk space.
Had this before and after a day of playing about with cleaning out the windows temp folders, I simply uninstalled all the driver and toolbox software, downloaded the latest version from Canon's site and reinstalled it. After doing a bit of research, found out it was caused by a windows update conflicting with the drivers
Dec 27, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Not enough space on target disc
If you are scanning in color choose JPG option as the file size is small. Delete unwanted files in the target location and create space.
S. Mohan
Dec 04, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Scanner sends message "Unable to scan. Make sure there is enough space on target disk"
Check the resolution settings.  If you're trying to scan at 9600dpi, the image will be huge, it may not fit into ram either, so the swap file would be used and you would need twice the file space to scan the image.
Scanning at 600dpi is generally fine enough for most uses (300 or less for web use), including scanning photographs (you may want to scan negatives at 1200 though.)
JBV^_^
Sep 01, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to scan, Make sure there is enough space on the target disk, There is about 200 GB.
check for disk partition permission, be sure you have full permission access.
Apr 07, 2010 | Canon CanoScan 4400F Flatbed Scanner
Using Canoscan Lide 70. When trying to scan receive message "not enough room on target disk" When I reinstall Toolbox it works (for a while, then same repeats).
When you scan a picture, you send it to a "Target" folder which you can set up in your scan options or settings.
At a guess your current destination or target folder is getting to large for the hard drive that its registered on
You've 2 options, clean out the target drive or use the scan options to send your pictures to a new destination with plenty of space.
Mar 05, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to scan.make sure there is enough space on the target disk
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Jan 24, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Error message: Can not scan. Not enough space on target disk
I have just cured this"not enough space on the target disc" on my set up.I had the problem from day one after buying scanner but learned to get around it.Today I went into Toolbox and opened settings and made a note of the target address. Then checked properties of the target folder and found there was 86mb in a space for 80mb.This was the default setting chosen by the installation programme. I went to my documents and made a new folder and called it Canoscan, clicked ok and it became the new target and the fault is gone. Hope it works for others.
Dec 29, 2008 | Canon CanoScan 4400f MultiFunction Color...
Scanning problem with a CanoScan8600F
Hi
 go to the your scanner properties please see there your current path.. and change the the path.. select your free hardisk space..which driver you've free space.. ther only stored you're all documents...
it will work
Nov 18, 2008 | Office Equipment & Supplies
LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
44 people viewed this question
old marine
old marine
