Question about HP Laserjet M2727nf Multifunction Printer
Will scan first page ok but all the next pages have drag lines on them.
  • 38 Answers
Check the toner, you might have bad drum in the toner. Try another toner, even an old toner that you know did not have problems should be ok to test with.
Posted on Jul 12, 2010
How to delete Page breaks in Excel
Move a page break Important To enable dragging of page breaks to another location in a worksheet, make sure that the cell drag-and-drop feature is enabled. If this feature is not enabled, you may not be able to move any page breaks.
To verify that drag-and-drop is enabled, do the following:
Click the File tab.
  1. Under Help, click Options.
  2. In the Advanced category, under Editing options, select the Enable fill handle and cell drag-and-drop check box, and then click OK.
  3. Select the worksheet that you want to modify.
  4. On the View tab, in the Workbook Views group, click Page Break Preview.
    2. Tip You can also click Page Break Preview za010181030.gif on the status bar.
    3. Note If you get the Welcome to Page Break Perview dialog box, click OK. To not see this dialog box every time you go to Page Break Preview view, select the Do not show this dialog again check box before you click OK.
  5. To move a page break, drag the page break to a new location.
Note: Moving an automatic page break changes it to a manual page break.
Delete a manually-inserted page break Note You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.
To delete a manually-inserted page break, do the following:
  1. Select the worksheet that you want to modify.
  2. On the View tab, in the Workbook Views group, click Page Break Preview.
  1. Do one of the following:
    • To delete a vertical page break, select the column to the right of the page break that you want to delete.
    • To delete a horizontal page break, select the row below the page break that you want to delete.
Note You cannot delete an automatic page break.
Jul 20, 2014 | Microsoft Excel 2010
I have replaced the imaging unit and it still asks for a new one how do i reset it
folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
May 19, 2011 | Samsung CLX-3175FN Printer
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
Hp2727 scan error
This is usually happening on Windows Vista or Windows 7, the problem is the driver. Download file hpiscn.dll and copy it into the install directory, overwrite if it asks. This should solve the problem.
Mar 19, 2010 | HP Laserjet M2727nf Multifunction Printer
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
I am editing a pagemaker file that has previously been printed. I need to keep the page from not reflowing...so if I take out just one space the entire document reflows...how can I stop that from happening
Can you elaborate a bit more what exactly is required ? What I undersand is that you need to remove a "one line space" from any page but do not want the matter from the next page to come in the current page.
Well if that is the case what you can do is remove the one line space or maybe more lines from page 1 (for example). If the matter from page 2 comes to page one, click on arrow tool and select the text matter on page one to select it. Click on the "+" sign at the bottom of selection and drag above the unwanted text.
I hope I have made myself clear.
Nov 03, 2009 | Adobe PageMaker Plus 6.5 for PC
SCANS PAGE IN TOO LARGE
Uncompressed TIFF files are large in size. If you want Black & white and also small size save in TIFF G4 format. JPG files are small, but only color and grey files can be stored in JPG format.
S. Mohan
Oct 01, 2009 | Fujitsu fi-5120C
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP Laserjet M2727nf Multifunction Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
