RTO Lawn Boy 6.75hp Mower Logo
Larry Brister Posted on Jul 11, 2010
Need new cable that controls the speed of the self propell craftsman 6.75 model #917.377650 21" rear drive
1helpful
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 • Garden
1helpful
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 • Garden
Craftsman 6.75 self-propelled...This is for a friend of mine. She has a broken arm and her mower will not operate as it should. The self-propelled function is not working. She spoke with someone who...
The self propel lever is the bottom one, the top one is the running lever. Have her check the cable coming out of that one. var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
2helpful
2answers
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
Wheels will not turn on craftsman rear bagger lawn mower
Is the lever pushed up where the self propelled should be engaged? Yesterday, my wheels stopped turning. I have a break in the cable that goes to the self propelled. I will have to replace the cable.
Mar 27, 2010 • Garden
7helpful
My craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Sep 04, 2009 • Garden
Top RTO Garden Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a RTO Garden Expert? Answer questions, earn points and help others
