Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
My fan wont run full speed when i set it to high speed on the remote it only runs about half speed
4 Suggested Answers
  • 833 Answers
SOURCE: Ceiling fan only running at highest speed
First, change the battery.  Second, turn off the power to the fan at the wall switch, if still installed.  If this doesn't fix it, it is probably dead.  Bring it back to Home Depot.  There may be a product bulletin.
Posted on Nov 15, 2008
SOURCE: Hamilton Bay Remote Control Ceiling Fan
Rempte light comes on but does not activate fan or light?? thanks
Posted on Apr 22, 2009
SOURCE: Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Posted on Jun 18, 2009
Cooling fan motor gets hot when running high speed why
Check the bearings. If the friction is high the fan will not run at rated speed. When it runs slower it uses more current and gets hotter...
Disassemble, clean and lubricate to make sure fan runs full blast and does not burn out.
Or if the fan has two windings, one for starting and one for running it is possible that the high speed run winding has some shorts in it resulting in more current and more heat.
Oct 13, 2015 | Cars & Trucks
M echo trimmer isrunning half speed
Start with one full turn out on the low side and the high side, then set your idle.
Aug 26, 2014 | Echo Garden
Re: Hunter Fan Model 27185 - 060 The above fan was purchased circia 5/1/2000 and does not now function properly (actually it has not been fully working for 4-5 years. It is installed in a 19' ceiing...
You either have a wiring problem possibly a ground rocked loose or the motor is going out.but if you press 1 while its running and it dies sounds like motor and nothing wrong with remote
Apr 26, 2017 | Hunter Heating & Cooling
My fan only runs on high. No low or medium speeds. The remote shows low, med and high changes but the fan only runs at high.
Check with another same type remote. If same problem, Check PCB. If all speed wires plugged properly? If yes, problem with PCB.Replace it.
Thanks, helpful?
Jan 18, 2011 | Hampton Bay Heating & Cooling
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
95 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
