Question about Vtech Kidizoom Digital Camera
My daughter's Kidizoom won't turn on - I have replaced the batteries and it makes no difference - I have checked the batteries in another console and they are fine. Any ideas?
    Problem Solver:
  • 5 Answers
I initially thought my batteries were dead, too. Try inserting a tooth pick into the reset hole. It can be found below the on-off button and slightly to the left. Apparently after battery changes, the unit needs to be reset. This worked for me.
Posted on Jul 23, 2010
  • mandsc Dec 24, 2010
    I have the same problem here, tried numurous new batteries and tried the reset button yet still nothing???? Any answers here before I ditch it????
  • critter2435 Dec 31, 2010
    how did you open it
Fresh out of the box and will not turn on
Why wait? Take it back for replacement.
Dec 28, 2013 | Vtech Kidizoom Digital Camera
I have changed the batteries on my vtech kidizoom camera pressed reset button it turns on fter a while but freezes
suggestions. Different type of battery? Two different brands of battery? check the internal contacts to see that they do not have corrosion from the old ones/
Nov 09, 2013 | Vtech Kidizoom Digital Camera
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
How do i charge up tthe kiddizoom camera for my daughter ?? it came with a usb lead that links up to computer and one other lead to connect up to television
The Kidizoom uses four standard AA batteries. You may use disposable alkalines or rechargeables. If you choose to use rechargeables, you much charge them using a separate charger. The Kidizoom is not a battery charger.
Oct 27, 2011 | Vtech Kidizoom Digital Camera
Hi My daughters Vtech Camera just stopped working suddenly have tried to change the batteries Put brand new one in the right way up and there is nothing happening at all have tried to press reset button...
Try the battery on another appliance to confirm the charge capacity or make sure there is voltage and current available on the battery. If so check the terminals on the camera, open and clean the battery terminals. If not there is a fault within which need that you need to open the camera. it can be a fusible link, fuse or a protection on the main board.
Feb 09, 2011 | Vtech Kidizoom Digital Camera
Turns on then turn right off
Change batteries, Two phillips screws on bottom. 4aa batteries. Just happened to my daughter. Hope this helps
Dec 26, 2010 | Vtech Kidizoom Digital Camera
Changed battery won't turn on
Try inserting a tooth pick into the reset hole found just below on-off button and slightly to the left. Apparently the camera requires a reset after batteries have been changed. Our problem after resolving this problem is now the camera doesn't always stay on, i.e., turns off by itself.
Jul 19, 2010 | Vtech Kidizoom Digital Camera
When i insert an sd card the vtech kidizoom camera wont turn on at all.
I am not a tech wiz but have just managed to put the card in my daughters camera! Normal SD card tight fit,it looks like it needs to go all the way in but doesnt. Either you have it in wrong or wrong card? Metal bits down! When I turned it on you then have to go to the tools sign to switch to memory card .Hope this helps.
Jul 25, 2009 | Vtech Kidizoom Digital Camera
Psp will not turn on unless the cord is plugged in
ok your son's psp has malfunctioned and instead of trying to charge the batteries it drained them. i would recomend for u to get ur son a new psp and buy a another battery for your daughter.
there is a newer battery being sold that you put AA batteries inside
to make it work. check out your local best buy and wal*mart
Dec 23, 2008 | Sony PlayStation Portable (PSP) Slim...
Y is it not working
The camera "thinks" it's connected to a TV. We had the same problem. My wife used a bobby pin to "trick" the camera into thinking it was being disconnected from the TV by probing the pin into and out of the TV connector on the side.
Sep 01, 2008 | Vtech Kidizoom Digital Camera
Vtech Kidizoom Digital Camera Logo
1,491 people viewed this question
Top Vtech Cameras Experts
ray gallant
Tom Chichester
Are you a Vtech Camera Expert? Answer questions, earn points and help others
