Hi i have one virus in my computer and he block my system and now i want to know if i can format my computer from command prompt but i type format c: and the computer tell me something about parttion can help me to resolv this
    Sniper:
  • 72 Answers
Why oo you want to format the C drive, you would not be able to do that. Why dont you try installing some antivirus and try to fix the virus.
In case you still want to format the hard drive and in the process remove the OS, you would need a bootable cd / DVD for the OS. You would need to start the process of re-installing the OS
First change the first boot device in the bios DVD, then insert the bootable CD in the CD Drive, restart the computer and follow the screen instructions, you would get an option to select new installation or repair the existing installation. Please select new install.
Then you would get he option to select the partition to install the OS. select the desired partition.
Then you would get the option to format the selected partition. select the disered option.
and follow the screen instruction an complete the installation.
Posted on Jul 11, 2010
How to Remove virus from Pen Drive/Flash Drive?
Steps To Remove Computer Viruses Using Command Prompt:
Step 1. Click on Start and type cmd. Now right click on the cmd icon and select run as administrator. Running the command as administrator is important as you need to access the system files which are not usually visible in guest accounts. Now command prompt window will open, now select your drive from which you want to remove a virus.
Step 2. Let us suppose your USB has a virus and your USB drive is F. Type "F:" without quotation on Command line. cmd-2-ut2cqzhdo2jgpvt0ug4dvtv0-4-9.png
Step 3. Now the C: will change to F: Now you need to type "dir F:" in CMD and hit enter. It will show you the directory of F drive. cmd-3-ut2cqzhdo2jgpvt0ug4dvtv0-4-14.png
Step 4. So now type the following command to show all the hidden and system files on your USB drive. Type "dir F: attrib -s -h /s /d*.*" without quotations and press enter. Typing this command will explore your selected drive and will load all the files including hidden and system files on your drive.
Step 5. In this window you will notice unusual file.exe and extention if your computer has been infected with a virus like the dreaded autorun.inf virus. Rename it using this command line rename filename.extension new filename. Usage > C://rename autorun.inf (new filename)
cmd-6-ut2cqzhdo2jgpvt0ug4dvtv0-4-27.png That's it! Now you can identify all the viruses in your PC and USB and delete them without any help of anti-virus software. You can delete the autorun.inf by typing in the command "del autorun.inf" or del :"yourfilename"
Oct 19, 2017 | Electronics - Others
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
Aug 07, 2015 | Dell OptiPlex GX270 PC Desktop
Remove virus
Insert your USB drive in the appropriate USB slot in your computer.
If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button.
Launch your anti-virus program, such as AVG Antivirus or Anti Malware.
Select the USB drive for the program to scan.
Click the "Start Scan" button or option.
Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software.
If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system.
Highlight each infected file in the scan history.
Write down the file name of each infected file identified on the USB drive.
Minimize the application's window.
Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive).
Press the Enter key.
Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes.
Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line.
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified in Step 4.
Close the command prompt window; that is, exit the Run utility.
Maximize the window for your anti-virus program (which is still open) and repeat Steps 2 to 7 until no virus is detected on your USB drive.
Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format.
another way is to control panel administrative tools computer management disk management Right Click on your drive select format
Oct 22, 2013 | Toshiba Computers & Internet
How to remove the virus from my mobile memory card?
Insert your USB drive in the appropriate USB slot in your computer. If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button. Launch your anti-virus program, such as AVG Antivirus or Anti Malware. Select the USB drive for the program to scan. Click the "Start Scan" button or option. Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software. If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system. Highlight each infected file in the scan history. Write down the file name of each infected file identified on the USB drive. Minimize the application's window. Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive). Press the Enter key. Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes. Press the Enter key. Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line. Press the Enter key. For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified in Step 4. Close the command prompt window; that is, exit the Run utility. Maximize the window for your anti-virus program (which is still open) and repeat Steps 2 to 7 until no virus is detected on your USB drive. Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format. another way is to control panel administrative tools computer management disk management Right Click on your drive select format
Hope this helps
Jan 12, 2013 | PNY 4GB microSD High Capacity Mobile Media...
U.S.B have some virus
or Click start click on my computer you should see your usb drive right click then select format. another way is to control panel administrative tools computer management disk management right Click on your drive select format
Hope this helps http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5 avg free 2012 http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Jan 10, 2013 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Virus of usb
or
Hope this helps
Nov 19, 2012 | Computers & Internet
Remove virus on hard disk and usb's
or
Hope this helps
avg free 2012
Fash drive virus
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified.
Maximize the window for your anti-virus program (which is still open) and repeat Steps until no virus is detected on your USB drive.
Sep 25, 2012 | Kingston 1 GB microSD Card with USB 20...
I can't get my usb flash drive to format
If you tell me what happens if you try to ormat the USB drive..
Can try to format using DOS command :-
click start - run - cmd - Format the drive letter(ex F:) and press enter..
Hope it helps and awaiting response.
Thanks.
Sep 14, 2009 | Electronics - Others
My folder option is not working.
1. Open Start>>Run and type cmd and press enter. This will open a command prompt window. On this command prompt window type the following steps.
2. type the drive name which is nt opening ...
   for example : if  "C" is not opening means ..
                      type    :    C: "press enter"
3. type   attrib -r -h -s autorun.inf
4. type   del autorun.inf
5. now type d: and press enter for d: drive partition. Now repeat steps 3 and 4. Similarly repeat step 5 for all your hard disk partition.
Restart your system and your trouble will be fixed
Mar 31, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
