Question about Fisher and Paykel GWL11 Top Load Washer
From left to right, the 3rd, 4th and 5th lights come on, the machine beeps and won't progress on to the rinse cycle or fully drain itself.
    President:
  • 2,468 Answers
One of 3 issues,find your tech sheet inside the machine,usually inside the control panel on washers and try to run the diagnostics shown on this sheet by pressing a series of buttons on the control panel,otherwise check the pump and drain hoses for obstructions,and also bypass the lid safety switch as this switch will kill power to these cycles if its defective,this can be done by opening up the unit and using a jumper wire temporarily to see if the switch is indeed bad
Posted on Jul 11, 2010
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Model Gw709AU
Feb 20, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
I have an 11 year old 5.5 excellence top loader by F&P. it won;t continue on with any cycle or programme. it wants to start, but after couple seconds it stops, then it tries again, and then stops,...
Hi just read your posting.When the machine stops and beeps a series of lights will light up on the wash progress line of lights.Starting from left to right which lights are lit when the machine is beeping,is it the 2nd and 6th or the 3rd and 7th etc?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Last cycle completed, maching beeped and washing taken out. Machine light is on rinse cycle and beeps will not reset to start new load.
Hi just read your posting.From the information in your posting you mentioned that the rinse light is on when the machine is beeping.Starting from the left to right on the wash progress lights which lights are lit when the machine is beeping,Is it the 1st and 6th or the 3rd and 7th etc?Please reply with this additional information and i am sure i can help you rectify your machine.Looking forward to your reply.
May 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
Won't drain out water, three lights on, first wash, first rinse, and spin. Beep every one second
Hi just read your posting.Could you confirm the lights that are on when the machine is beeping.Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 3rd or the 4th and 7th ---etc---?Please reply with this information and I am sure I can help you.Looking forward to your reply.
Sep 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine get to the spin & rinse cycle and doesn't spin. Does this espicially when it gets warmed up. It is
Hi just read your posting.Now does the machine drain the water out?Does the machine stop and beep and show a series of lights that are lit when it is beeping?If it does they will be in a row of 8 lights.Starting from left to right which lights are lit,Is it the 1st and 3rd or the 4th and 7th ---etc---?Please reply with additional information and I will be able to help you further.Looking forward to your reply.
Sep 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer stops when it is in the draining proses almost when it has draining all water and it wont continue
Hi just read your posting.Now when the machine stops does, it beep and show a series of lights.If it does show lights that are lit then they will be in a row of 8 lights.Starting from left to right which ones are on?Is it the 2nd and 4th or the 5th and 7th ---etc---?Please reply with additional information and I can help you rectify this problem.
Jul 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
