Question about HP Business InkJet 2800 Printer
Hp 2800 printer will not boot after multiple attempts at cycling the power all that happens is the green light and scrolling dots on the display screen
    Problem Solver:
  • 5 Answers
In all likelyhood, a capacitor on the main pc board had blown, they problem caps are TEAPO 6.3v 680uf. Look at the caps and see if any of the tops of bulged up. If so, replace the caps (about .14 each). The caps control voltage to the actuators, without which, the printer's OS never gets past initialization.
Posted on Sep 14, 2010
  • lmphashby123 Apr 03, 2011
    can you please give instruction on taking the cover apart to get to this capacitor? So far I only see two screws and nothing comes off.
    anyone with directions would be helpfull
    i just took apart this monster only to find that there is no capacitor by the name of TEAPO 6.3V 680uf on the mother board \. Im not sure what youare refering to but you information is so not clear
Hp officejet 9120 won't power down but won't print either, it seems to be locked up, display just shows dots scrolling right to left
Unplug your printer from the outlet for several minutes and repower it back up. I have had this with my printer and usually solves the problem.
Jan 02, 2012 | HP OfficeJet 9120 All-In-One InkJet...
Hi i am not able to print in color, even though my settings are to print in color and the cartridge is nearly full. I have an all in one printer HP FA2480
Pls reset your printer.
1.Switch the Printer ON by pressing the Power Button (Make Sure Paper is not Loaded)
2.Once switched on, hold down the Power Button (DO NOT RELEASE)
3. Now press the Cancel Button and let go of it
4. Now Release the Power Button
5. Wait...
6.The INK LED will light up,
7. After a while it will attempt to print a sheet but because there is no paper the resume button will blink
Now press cancel
You have completed the steps and now should be able to print if not attempt this again from STEPS 1-7
Feb 09, 2011 | HP DeskJet F4280 All In One Printer InkJet
My HP 2800 is completely dead. I bought a new power supplay but again nothing..... Please help me !!
Ypou maybe right and it is dead. Try other options like what happens when you plug it in. Listen to it when you do that. And please, I do not mean anything here....but does the power supply have a light that glows when you plug it in?
Nov 02, 2010 | HP Business InkJet 2800 Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
The power cables are working The printer clearly
i think you should check the cable that connects the printer to the computer. I suggest you change the cable and see if it works.
Aug 05, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Business InkJet 2800 just displays rows of asterisks,never boots.
it may want to replace the formatter board, call your HP repair center
Mar 22, 2010 | HP Business InkJet 2800 Printer
When power applied to HP2800 PLC6 green light illuminates and dotted line draws across LCD screen. no other response. no buttons work. Is this abad one?
Most probably the power supply has gone bad , and caused damage to the main board.
I don’t think this is worth the repair costs. Still working on it.
Nov 19, 2009 | HP Business InkJet 2800 Printer
How to change a fuse in the hp 2800 printer, power up problems
There are 2 fuses inside the power supply unit.
The hard part is getting to the power supply! The power supply is located at the left side of the printer and in the front (the opposite side of the cartridges).
You have to remove the side and top covers.
There are some hidden screws. One is under the button faceplate that you will also have to remove. The entire procedure is tricky especially without a service manual. Unfortunately I couldn’t locate a manual.
Caution always disconnect the power lines and allow some time for capacitors discharge before you attempt any repairs.
I hope you have some luck with yours !!
Nov 13, 2009 | HP Business InkJet 2800 Printer
Green on/off button not working. Just HP logo in display box disp
Open the printer and check the voltages at the power points. If they are present then power module is ok.
Jul 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Appearing dots on printer screen
pls check the cartdriges and clean head first. and plug it, power on again your printer. try to print.
Jun 07, 2009 | HP Business InkJet 2800 Printer
HP Business InkJet 2800 Printer Logo
955 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
