Question about SanDisk Sansa c200 MP3 Player
It will turn on then off ><
When i press power the label on the mp3 player will come on then shut off right away
  • bigrey May 13, 2008
    THE SANDISC LOGO WELL APPEAR THEN IT WILL TURN OFF
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 27, 2008
My mp3 doesn't turn on but when i put it on the computer, the mp3 turn on then i unput it turn right away turn off
When you plug it into your computer, press "USB Charge" on your V-Touch. This should charge it while its pluged into your computer.
Feb 21, 2012 | Visual Land V-Touch Digital Media Player
I cant seem to be able to turn it on because i cant find the power botton.
Hello!
Many Mp3 players often times have no power button, or a On/Off button. Although they probably should, many companies allow buttons to play multi tasks in the ever increasing need to save space.
Most times, pressing the play button, or holding the play button (signified by a right facing triangle) is used to start the mp3 player.
Ipod's do not have a "on?off" button either, you can simply press any button to make it start. holding the play button will allow it to go into a power save mode and "shut down" as well.
There is often a "lock" button you may have to slide or press in order to get it to turn on. This button is there so to no accidentally turn on the mp3 player when you dont need it, and waste battery life.
Hope this helps!
~Daniel.
Dec 28, 2010 | Audio Players & Recorders
How do I bookmark or save my place in an audio file
Try and press pause before you shut the player off.
Mar 30, 2010 | Coby MP-610 MP3 Player
My Insignia Sport will not turn off
on the back of the player there is a small black dot toward the top of the battery cover remove it to reveal a small eyeglass type screw remove it with an eyeglass repair kit or a straight razor remove the battery cover very gently there is a small wire attached to the battery at the bottom of the wire is a plastic prong with your fingernail gently pull the prong away from the player wait a few seconds and replace it press power and your player should start back up
Aug 18, 2009 | Insignia Sport MP3 Player
It shut off.
Turn it on by holding in the power button - it is normal for that model to go to sleep while it is playing, as a powersaving feature - but it shouldn't stop playing the music, the screen should just go away. Usually pressing any key will wake it back up.
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Won't turn on.
dunno happened to me but its started working again
Dec 09, 2008 | Mach Speed Trio Portable MP3 Player
Sansa mp3 player.
Question: How do I reset my Sansa?
Answer: Press and hold the Power/Menu button down for approximately 15
seconds.
http://www.sansa.com/support/sansa_e200/faqs
Nov 09, 2008 | SanDisk Audio Players & Recorders
Player shuts itself off
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Aug 22, 2008 | SanDisk Sansa Clip MP3 Player
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
Shuts off right away
is it possible that you aren't holding the button long enough?
Mar 10, 2008 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
