Question about Acer AL2671W 26 in. LCD Television
The unit will not switch on from the remote or the button which only glows orange and will not turn blue. What can be done?
  • Acer Master
  • 11,800 Answers
Take it to a repair shop, the orange glow signals a fault in the power source of the tv and it must be fixed by a pro.
Posted on Jul 11, 2010
Cannot get BluRay/DVD system to respond to remote commands. Only the Samsung TV will. I cannot figure out how to switch the remote into giving only BluRay/DVD functions. I've read this unit has a...
Yes, the reason for this is that the BD-Receiver/TV button was pressed twice. This button has 2 modes of operation depending on the color it flashes when you press any button on the remote. If the BD-Receiver/TV button flashes green then it is in TV mode and if it flashes orange then it is in BD Receiver mode. The way to switch between the 2 modes is simple but not intuitive and easily not noticed. Simply press the BD-Receiver/TV button it will light-up green or orange, depending on what mode it is in, for about 1 second. The trick is to quickly press it again BEFORE the light goes out. When this is done the color of the light will change. If it was green it will change to orange and vice versa. Rember, Orange = BD Receiver function Green = TV
Hope this solution has been helpful?
Thank you for visiting FixYa.
Aug 20, 2011 | Samsung HT-C6730W Theater System
I have a HP pavilion entertainment PC laptop.The wireless button of my laptop has turnedd off and not getting on.Please help me.
hpweb_1-2_minus.gif Wireless device is turned off or disabled The power to the wireless network and Bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme, see the user guide for more information. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02448899.jpg and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02448900.jpg will display.
  3. You can also try pressing the fn+ F2 keys simultaneously to enable the wireless device.
Apr 24, 2011 | Computers & Internet
I am having trouble connecting to the internet because my WLAN has been turned off, how do I turn my wireless back on?
From the HP website:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme. To turn on and enable the wireless device, do the following:
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02228164.gif and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02228163.gif will display.
Apr 18, 2011 | HP Pavilion dv4000 Notebook
My wireless internet switch will not turn on.
Apr 17, 2011 | HP Computers & Internet
Pres remote starter Model APS-901, the remote will start the vehicle but then it immediately shuts off
PLEASE READ THE ENTIRE POST BEFORE BEGINNING
There are several reasons that could cause the remote starter to shutdown immediately after it starts:
1. It may be the lack of a tachometer signal. Did you hook up the green/orange wire to a uncommon wire at a coil or fuel injector? If not, did you program the remote starter for tachless? If you didn't hook up the tach wire, no problem; let's program the remote starter for tachless:
Turn ignition on, press and release programming switch three times. The parking lights will flash one time. Turn key off, then on, then off, then on. You are now in bank three (remote starter programming). Press and release the programming button five times. The parking lights will flash the number of the times for the setting for this feature. If you have not attempted to progarm the unit, it will flash two times (default setting is for TACH). Press and release the start button on the remote once, it will flash three times; press and release the start button again, it will flash once. The unit is now programmed for voltage. Turn the key off. If you have not attempted to do any programming on the unit, the default setting for crank averaging is AVERAGING. This means that you will have to start the vehicle at least four times with the key to be effective. Test the system.
If the problem still exists, let's try this:
2. If you did not hook up the tach wire and you already had the unit programmed for voltage and, the remote starter shuts down (probably when the parking lights come on); the 901 is seeing a drop in voltage and you need to hook up the tach wire. Connect the green/orange wire to an uncommon wire at a fuel injector or coil. An uncommon wire is one that is a different color, at the same pin location, on each coil or injector. For example; compare two fuel injectors: if they are two pin connectors you may see an orange and a pink. At the next injector you may see an orange and a blue. The orange is the common wire and the pink and the blue are uncommon wires. You may connect the green/orange to either one of the uncommon wires. After the wire is connected, turn the ignition on, press and release the programming button three times. The parking kights flash once. Turn the key off. Press and HOLD the programming button, start the vehicle. The parking lights will begin to flash, continue to hold programming button for approximately 15 second. Release the programming button, the parking lights will come on then, go off. The tach is now programmed. Turn vehicle off. Refer to the above section for remote starter programming features in bank three. Test system.
Remember: If you did hook up the tach wire there is no need to program the 901 for tach. Tach is the default setting.
3. If the remote starter still continues to shut down, the problem may be with your need for an immobilizer bypass. You failed to mention the year/make/model of the vehicle so, try inserting the key into the ignition then, remote start the vehicle. If the vehicle starts and runs, you will need to bypass the "chip" in the key for the remote starter to function as desired.
Nov 06, 2010 | Audiovox APS901 Car Prestige Remote Start
My built in wireless network adapter is no longer detecting any networks. It is an hp pavilion dv 2500. Is there a way to fix this problem; do I need a new adapter? If so, where can I get one?
The new hp units have a touch switch on the top panel. It should be blue when on, otherwise it is orange/yellow. Just touch the icon to change the status from off to on, then check for networks.
The paragraph below is from the hp website on wireless unit problems:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is quite common to accidentally bump the button and turn off the wireless service. On most computers there is an LED light that glows blue when there is a wireless device is turned on and enabled.
This is the link to that site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00812738&cc=us&lc=en&dlc=en&product=3379103
Good Luck
Feb 01, 2010 | Computers & Internet
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Prescario v6000 mute buttons and sound button dont work
you have to install the driver
get you driver driver through hp site
Oct 04, 2008 | HP Compaq Presario V6000T Notebook
Compaq laptop won't connect to internet
on my hp the light is blue when switch is on. go to network and conn. and make sure ur wireless is turn off there. cause if my switch is in the on position and i turn it off hp wireless assistant the light will glow orange eventhough the switch is on . ? Just had an issue simular to this one, hope it helps.
May 19, 2008 | Computers & Internet
Acer AL2671W 26 in. LCD Television Logo
288 people viewed this question
Top Acer Televison & Video Experts
Rommel Balcita
Martin Murray
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
