Question about Zanussi TD4112W Electric Dryer
Onlyheating up very slightly while drying.
Only heating up very slightly while drying. Clothes take an age to dry. No steam coming from outlet
  • Zanussi Master
  • 43,501 Answers
Hi, If you have a gas dryerOnlyheating up very slightly while drying. - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a Onlyheating up very slightly while drying. - 2_bing.gifdifferent problems...
Check out this tip that I wrote about this problem...
Troubleshooting2_bing.gOnlyheating up very slightly while drying. - 2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
My new vaporella 650 steam iron is making my clothes wet whilst ironing as it drips water constantly
Clothes are very difficult to iron when they are fully dry or over-dried in the dryer. Over-dried clothes are resistant to reshaping, which it exactly what ironing is. Removing clothes when they are still slightly damp will make ironing much easier. If you line-dry your clothes, bring them inside to iron when they are not quite dry.
Nov 12, 2017 | Irons
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
Dryer heats sometimes and other times it does not. tested heater element and fuses and they were good. replaced both thermostats and it still does not heat well. any suggestions
You did not post make or model, so I can't be certain what technology your dryer employs or it's age. Here is my suggestion... Have you cleaned the lint trap area all the way to machine exit? How about the hose to the outside, is it clean and not bent or restricted? If there is a restriction, the steam cant escape and and it will take forever for the clothes to dry. I'd also check to see if there is air coming out the exhaust. If not, check to see if the fan is clogged with lint, intermittent or missing. If no air flows through the drum, it will keep it hot and moist, and never dry the clothes.
Jun 17, 2012 | Dryers
The appliance works but does not heat sufficiently to dry the clothes. The appliance can run for ages but not dry the clothes?!
You will need the thermostat or heating element replaced. if you need instructions on how to do this please post back with make, model, and model number.
Dec 01, 2010 | Dryers
I have model 110.60832990 and the dryer is on the drum is turning, the heat is on but the clothes are not drying.
Check the air outlet and see it is not clogged with dirt/flint. Clean the air filter mesh located at the air outlet of flint. This blocks the free flow of air and thus do not dry the clothes. Drying will take place when the air inside has free flow. Before putting clothes in the dryer EVERYTIME this filter must be cleaned OR after every drying cycle.
Aug 29, 2010 | Dryers
Is it normal to see steam coming out of the dishwasher in the drying cycle?
Yes, The colder the room its in the more steam you will see. It will look like more steam if sun light is shinning over it. Just like your clothes dryer blowing steam out side. Its just drying.
Oct 30, 2009 | Dishwashers
My dryer is heating up but isn't drying the clothes
I would be REALLY suspicious of the exhaust vent. If the dryer is heating up and the drum is turning, it has to dry the clothes UNLESS there is no air going through the dryer. Disconnect the air outlet flexible plastic duct at the back of the unit, and turn it on. If there is no or very little air coming out, the inside of the unit will be plugged with lint. If there is lots of air coming out, the exhaust duct or the outside flapper will be plugged. Sometimes if the exhaust is routed through a cold space there will be so much condensation in the duct that it will droop and literally fill up with water.
Sep 09, 2009 | Whirlpool Dryers
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer problrm
The sympoms are typical of a couple of reasons.
  1. Blocked condenser.
  2. faulty cold inlet valve, not letting water in to condense steam back to water.
When it is on the drying cycle, see if you can see water pumping out of the drain at. a slow rate.
If you can see no water at all coming from outlet hose, then chances are it is a faulty valve, and you will have replace same.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Zanussi TD4112W Electric Dryer Logo
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
