Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Cannot remove pump cover from bosch washing machine
Unable to remove pump cover from bosch logic x washing machine
SOURCE: washing machine replacement door seal
It is held on by a spring that stretches around the outside of the seal. The seal simply hooks on to a small lip so all you need to do is start in one spot and push it down and away. Then just work it around like removing a bike tire until it is fully removed. Be careful of the spring. It is hooked together so it may unhook once some of the tension is removed and snap around.
Posted on Nov 17, 2007
  • 77 Answers
SOURCE: LG Fuzzy Logic
it could be the sensor that detects that the lid is closed during every cycle.try hitting the lid when it stops it might work
Posted on Feb 12, 2008
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: cannot remove pump cover on front-load Siemens S16.76
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
Bosch WFB 2005 Pump Cover Stuck
You can replace the pump and not have to buy a new machine.
May 19, 2012 | Washing Machines
Trying to remove pump cover on bosch front load washing machine. Will unscrew 45 degrees then turn no further. Can not pull it out from that position
Trying to remove pump cover on bosch This video will show you how to change the pump washing machine
Jan 04, 2011 | Washing Machines
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
I have a Bosch washing machine (Classixx) which has been problem-free since I bought it just 6 years ago. Today I tried to clean the drain pump to check for debris / fluff. I've never done this before, and...
look for a small hole in the cover with a wire you can press the release tab.. remove bosch pump cover 1) insert wire in small hole in cover 2) while pressing in on wire twist cover 3) remove cover 4) with the handles of plires twist off pump cover Let me know if it helps or I can go deeper into it.
Sep 26, 2009 | Bosch Washing Machines
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
Bosch washing machine show E;04 plugged drain hose or pump
Remove cover to gain access to water pump, low rightside of front panel. Clean water pump. You should be good.
Jan 31, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Error E;04
Located front down on right hand side. Remove cover gain access to water pump.
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
499 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
