Question about RIM BlackBerry Curve 8520 Smartphone
Even after hard reset the phone loads up and freezes
Even after hard reset the phone loads up and then goes to clock and the key board is unresponsive, the time is moving so its not completely frozen but i cant do anything with it. The light is also flashing continuosly, any help would be brilliant.
  • 28 Answers
Well try deleting sample media files and browser caches and pulling the battery to free up temporary memory you should pull the battery at least once a week and if your a heave net user on the blackberry delete caches daily if not a heavy user every 2-3 days is fine
Posted on Jul 11, 2010
Phone freezes cannot do a factory reset
May I assume you have already tried a "hard reset"? (There are several easy-to-follow instructions posted on YouTube - just search for "Galaxy Y hard reset"). If so, see below. If not, know that the key part is to remove the battery before proceeding. If you're really lucky, the phone will boot up normally and everuthing will be fine; if not, the hard reset procedire, if it works, will boot up a factory reset device, which will PERMANENTLY wipe all apps and data from your phone. But at least the phone may work. If, however, the phone won't even begin to boot after removing and replacing the battery, your phone is - sadly - most likely "bricked." It may be revivable using professional tools, or at least the data may be recoverable, but it is probably not worth the considerable expense! Instead, it would surely be time to move on to a more modern device, such as the S4 or S5. Hopefully, your data is properly backed up, so it can all be loaded onto your new device. If not, you may be SOL...
Sep 06, 2014 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
Samsung sch-u340 wont start up
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Samsung SCH-u340 Cellular Phone
I have an F7 code on my gas range that keeps beeping
F7 code usually means a stuck key on the key pad. Some of the keys can be unstuck, but if high heat caused the pad to warp it might not be repairable.
  • Turn off power
  • Disconnect the key pad from the clock
    • If code goes away key pad is at fault
    • If it does not the EOC (electronic control board) is at fault
You can try giving the oven a hard reset by disconnecting the power for 20-30 minutes, then restoring the power.
Apr 17, 2011 | Maytag Ovens
My phone wont start up with any sim card in but it starts ok without one it gets the initial nokia logo and then it goes to a white screen and freezes occasionally it works ok but then freezes again
Hi
Your phone got infected by a phone virus. Usually a hard reset can help solve the problem. Most nokia symbian series phone can be reset using this code *#7370# and the default key is 12345.
Hope is helps. Thanks for using Fixya.
Apr 01, 2010 | Nokia 6100
My HTC Mogul keeps freezing, wont even get past the main screen when I start it up, I loaded a larger file onto it and started it up, since then it hasn't worked. Anyway to do a hard reset by hand without...
you can try a hard reset. Hold down the left and right softkeys (the two buttons above the windows button and the ok button) and use the stylus in the reset button (bottom of phone just below the sd slot) This will erase verything off your phone, but should fix the problem.
Jun 16, 2009 | HTC PPC-6800 Smartphone
Black berry Storm keeps freezing up on me
mine did the same thing, but i went into the phone and checked "NO" to the mass storage mode support. to get there....go to "options"...then click on "memory". then turn off "mass storage mode support".
Feb 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
Coby MP-705 Frozen after loading Files
that's the exact same thing that happened to me. I don't know what to say but once a while after it kept happining it stopped cause if you use windows media player to sync, e-mail me back and i might have a soulution.
Jan 30, 2009 | Coby MP-705 Digital Media Player
The phone keep restarting and not responsive
Connect your phone to the computer in file transfer mode and remove all the files that are created by that software. If windows explorer does not show files, try Mobile Explorers like FExplorer.
Jan 21, 2009 | Nokia E71 Smartphone
Camera trouble
TIMSTEPH - you cna do a hard reset *2767*355# or take the phone to a mobile center and have it reflash.
FLORANCY - reflash the software or do a hard reset *2767*3855#
GUEST - hard reset *2767*3855#
Nov 16, 2007 | Samsung SGH-D900 Cellular Phone
RIM BlackBerry Curve 8520 Smartphone Logo
333 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
