SOURCE: Invoice & Order Minimize Data Entry - Especially Name and Address
Do you have Microsoft Access? If so, you could use that to create a database and an invoice form. You could also use Access to "dump" the info into Excel to track and record.
Otherwise, try searching for "Import Data" in the Excel help. It would be very difficult to walk you through the whole process, but if you have specific questions about certain steps, that would be more manageable.
SOURCE: Corrupt MYOB data file
Our MYOB 14 .dat file is crashing. We suspect a corrupt entry in the database. The file will open but as soon as we trying to do anything the program closes and produces the following error: MYOB must terminate. Termination Code 1284 Important Details: Error -3000 in DMGTEKey (5037:7000:69) Seems to be the same error every time. We have tried running MYOB's Verify and Optimise tools with no luck. Each time either tool is run the program crashes and displays the error: An error occurred while attempting to compact the database. DM Error = (-3000-5049-7000-158) Restoring from a backup is not an option as last backup was 3 months ago. So looking for solutions to fix the current file please. Will not be satisfied if the solution is to take it to MYOB. Need someone who can actually dig around inside the file and correct the errors??
Insert a CF FLASH CARD into the front of the register before taking a "Z" report. Turn the manager's key to Z1 and press CASH AMOUNT TENDER to issue a BATCH report of all sales activity, which prints from the register's receipt printer. This report information is also automatically written to the CF Flash Card capturing the register's terminal number and date of the report. This data is formatted as a "TXT" file and can be open with Microsoft EXCEL. Use EXCEL to combine multiple register totals. Create historical report data and e-mail the reports to corporate or to district managers. Saves time and reduces transposition errors.
Use the CF Flash Card to save the entire register program before moving the register to a new venue where it can be reprogrammed in a flash with the new menu.
