Question about Canon iP100 Portable Printer
Orange light keeps coming on and I cannot print anything. It gives an alert on my lap top to say USB non compliant. Canon ip 100 series. A non compliant device is connected to the direct port or bluetooth unit connector. Disconnect the cable from the direct print port or blue tooth unit. It has only happened since my cousin put my camera connection directly into the printer port to print off photos. Now I cannot get the orange light to shut off. I cannot print anything this pops up on my lap top all the time I want to print anything. Very frustrating.Thanks for advice on fixing problem.
  • miacci Jul 11, 2010
    Hi Steve,
    I tried everything you suggested but the bloody thing still wont print and the orange light is still flashing so I cant print anything! Any other suggestions? THanks
    Novelist:
  • 113 Answers
try removing the camera software that was presumably installed.
If not, can you try a System Restore? Sys Restore will restore your laptop to an earlier time. Try a restore date prior to the date the problem first occurred. (Sys Restore in WInXP is accessed thru Start/Accessories/System Tools- Restore dates that you can use will be in BOLD font on the calendar)
Cheers,
Steve
Posted on Jul 11, 2010
Testimonial: "Quick response (I dont think he sleeps!) sound advice that was really helpful."
  • 3 more comments
  • Steve Jul 11, 2010
    Hi Miacci,
    Can you describe the orange flashing light sequence?
    Not sure if you have the manual but get it here:
    http://support-au.canon.com.au/P/search?...
    Download it, then Install it, open the on-screen manual, and then look under the Troubleshooting section/Orange light flashes - there are 12 different errors dependent on how many orange flashes you get.
    Cheers,
    Steve (Melbourne,Australia)
    Hi again,
    did your cousin install this by chance?:
    http://support-au.canon.com.au/contents/...
    Cheers,
    Steve
  • miacci Jul 12, 2010
    Hi Steve,
    Thanks so much for the advice I did download the manual and I had 9 flashing orange lights and was able to remove the printer software and reload and the problem was fixed. So thanks again for your support I appreciate it.
    Cheers
    Miacci
  • Steve Jul 12, 2010
    Hi again Miacci,
    No worries. Glad to help!
    Feel free to vote for my answer and to add a testimonial to
    my name. :-)
    Cheers,
    Steve
  • Steve Jul 16, 2010
    Hi again Asnish,
    get the manual here:
    Install it, go to the Users Guide section, then to Troubleshooting, then the Alarm lamp flashes orange section.
    Nine flashes: No response from connected digital camera or video camcorder. / Connected digital camera or video camcorder is not compatible with this printer. / PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector. / Bluetooth units are attached to both Direct Print Port and Bluetooth Unit Connector.
    A communication time out occurs if printing takes a long time or if it takes too much time to send data. This may cancel printing. Disconnect the USB cable connecting the printer and the device, and then reconnect it.
    When printing from a PictBridge compliant device, depending on the model or brand of your device, you may have to select a PictBridge compliant print mode on the device before connecting it to the printer. You may also have to turn on the camera or select Play mode manually after connecting the device to the printer. Perform necessary operations according your device's instruction manual before reconnecting it to the printer.
    Check the device connected to the Direct Print Port or Bluetooth Unit Connector on the printer. PictBridge compliant devices or the optional Bluetooth unit BU-30 can be connected to the printer for direct printing.
    When PictBridge compliant devices are attached to the both Direct Print Port and Bluetooth Unit Connector on the printer, disconnect both PictBridge compliant devices and connect either of the PictBridge compliant devices again.
    When the optional Bluetooth units BU-30 are attached to the both Direct Print Port and Bluetooth Unit Connector on the printer, turn off the printer, and then remove either of the Bluetooth units. For details on how to remove the Bluetooth unit, refer to the Bluetooth Guide on screen manual.
    Good luck,
    Steve
On my iP100 The orange light blinks continuosly and says ther is a paper feed erro, but I cannot find any paper jammed anywhere...it will not print at all.
Any ideas?
Posted on Jul 20, 2010
Hi guys i still have the same problem but i can't solve it
the thing is, i didn't attach any camera on it but it the alarm light flashes nine times . and the funny thing is when i attach a camera on the direct print port , it will began to work properly. do u have any idea what will be the problem
Posted on Jul 16, 2010
  • 2 more comments
    Hi Asnish,
    did you download the manual as per above info?
    http://support-au.canon.com.au/P/search?... iP100
  • asnish Jul 20, 2010
    Hi ,
    i had already download and read the manual . but it won't help me
    the manual said to unplug anything on the direct print port
    but i didn't plug anything on it . Besides i changed a pc to check whether it is the PC problem . but still the same error is happening. But when i attach a camera on it , it will began to work properly and when i unplug and restart still the same message appears. do u have any idea what is the problem
  • goonsurfer Mar 30, 2011
    Hi Asnish,
    I have the same problem......called in a repairman who found ink leaking into into both ports shorting things out.
    Now I mop the ink with blotting paper before use...it's a pain....but at least I can now get the machine to work....till I can replace it.
I have a Canon Pixma IP 4000 and keep getting the error message that the ink absorber is nearly full. Print quality is not good even after cleaning. What should I do?
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon iP 5200 orange light flashing 5 times
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair. I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Dec 22, 2009 | Canon Office Equipment & Supplies
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
When I turn my IP 3000 on the green light only blink 9 time no orange light at all I did try to reset no sucess as the green light keep blinking 9 time any help
9 flashes should only occur if you are trying to print directly from a non-compatible digital camera. Check where your USB cable is plugged into the printer. The cable coming from the computer should go into a 'square' port in the back of the printer -- not the rectangular port on the lower right side of the front of the printer.
Nov 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
Ip 5300 error b200 10 blink orange-green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Sep 26, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
No print
Hi there you can try this.
Canon IP 2000 / 3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon iP100 Portable Printer  Logo
1,507 people viewed this question
old marine
old marine
