Question about Navman Trackfish 6600 GPS Receiver
Information not displayed.
The C map chart page is not displaying information on my 6500. It says no data available. The GPS is working
2 Suggested Answers
  • 3 Answers
SOURCE: no map data available
give more details
Posted on Jun 03, 2009
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Navionics card wont work
You most likely need to change the map data displayed.
The elite series won't change for you automatically. Lowrance Elite 7 HDI Hybrid Dual Imaging Fishfinder Chartplotter
here is a link to the elite 7 page where you can download a pdf owners manual.
go to the gps/map page on your unit. Find "chart data" on your menu.
select nation is as your chart data. Then you will be ableaving to see your map data.
Jul 30, 2014 | Lowrance Elite7m Chartplotter With Gold...
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
What memory card does the 5505 take
CLICK HERE for all the info.
CLICK HERE for the Manual.
Your specific question's answer is on page 7 of the manual:
C-MAP™ chart cards have chart details required for navigating in a particular region. When a chart card is plugged in, the extra details automatically appear on the TRACKER chart display.
The TRACKER can use NT, NT+ and NT-MAX cards.
C-MAP™ user cards are used to store navigation data. Each user card expands the TRACKER memory and allows the data to be transferred to another TRACKER easily (see section 14).
Note: The older 5 volt user cards are not supported.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2010 | Navman TRACKER 5505 GPS Receiver
Lcs-20c GPS slow with HotMaps Premium 09 card
Does the image come back by itself if you slow down or stop and wait? If not, make sure you are not leaving the coverage area of the chart you are set to. In the LCX-20, that Navionics chart is split up into several sections, if you have one section selected and are on the border and then leave that area, the map usually goes all white depending on your zoom level. If you are on a border like that you will have to learn to quickly switch the charts from the MAP DATA menu.
If the map does catch up when you slow or stop, and just can't redraw fast enough...
Make sure the LCX-20 has the latest updates which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
These updates often add additional Navionics support.
Most likely though, this is just going to be the way it is with that particular map and the LCX-20. If you zoom out it will be much much better. So if updating doesn't help, zoom out. Experiment to see how close you can be zoomed in while running above 20mph. If you can get a good zoom level to where the map can keep up and you can still see the information you need then you should be good to go. If not, use the LakeMaster card or go get a different mapping option...or upgrade your display unit.
Jun 24, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
"No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Dec 12, 2008 | Garmin Nuvi 350 Car GPS Receiver
How do you get the gps to show depth and markers on the water?
It depends on what model you have. Most chartplotters require a chip with regional chart data. Most Lowrance models use Navionics charts. If you have a chip in the GPS, go to the map screen and press the "menu" key. Somewhere in the map setup menu will be a field where you can specify which chart to display.
For example a Navionics gold chart may cover the entire east coast, but it is broken down into a few sub regions. If you are boating in New England you would select the sub region labeled Northeast. Some of the earlier models didn't name the regions, they used model number for each region such as "XL904G". In that case your best bet is to try each one until you can view the charts in your area. Zoom in to 1/2 mile scale to make sure you can see charts.
If you have done all that and still can't see the chart details, there is also a setting in the map setup menu that allows you to set the level of detail. Make sure it is set to normal, more, or most. If you see a declutter setting on the setup menu, try setting it to off.
Jul 21, 2008 | Lowrance GPS
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
Navman Trackfish 6600 GPS Receiver Logo
16 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
