Question about Panasonic Cameras
Memory card is locked, how do I unlock this?
My memory card is locked, I'm trying to delete all photos and videos as I've now downloaded, I now need the space again, how do I unlock this?
Many thanks
  • 28 Answers
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Posted on Jul 11, 2010
2 Suggested Answers
  • 26 Answers
SOURCE: memory card is locked
There is a small tab (like a very small hole with a sliding piece of plastic) on the corner of the memory card. Slide it to unlock it :)
Posted on Dec 17, 2007
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Jan 02, 2017 | Tablets & eReaders
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
I accidently deleted my wedding pictures from my pny memory card/Nikon 5100 camera, can I restore them
I've used Recuva (free download). Do a thorough deep scan and save to another drive. Very simple to use as long as you have not reused same physical space on card.
http://www.piriform.com/recuva
Sep 23, 2012 | PNY 2GB microSD Memory Card
I've lost my photos
Videos and photos are the best means to cherish good old days. At times due to accidental deletion of photos and videos or formatting of the memory card results in the loss of important clip. However, you still don't have to worry as Kernel for Windows Data Recovery tool provides you with a safe and risk-free alternative to get back all the lost or deleted photos and video files from memory card in every condition. For more info visit http://www.recoveryfiles.net/
Jul 20, 2012 | Cameras
Can I recover photos from my digital camera svp aqua wp5300 I accidently deleted?
Well, chances of recovery can be high as long as you act as soon as possible and stop using the digital camera to take more photos or videos, also keep the camera memory card in good shape (no physical damage).
Then you can rely on a digital camera data recovery software to get the job done and retrieve your photos. Here shows a list of good ones (for PC/Mac) http://www.digital-camera-recovery.com/
You'll need to connect the camera (mass memory card) to your computer. Then install the program to start scan & recover your files.
Should be easy to get back your lost memories!
Best regards!
Nov 29, 2011 | SVP WP5300 Digital Camera
I'm trying to recover all of my photos that I accidentally deleted from my memory card.. It's not coming up as a driver when I plug it in, so I'm not sure how to get them back. I have a Canon...
Hi, buddy! Watch this video and you will find a good way to recover your lost photos in your memory card.
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
GT Recovery for Windows Download: www.gtrecovery.net
Sep 13, 2011 | Cameras
I deleted photos ,on the camera, that I need. How do I retrieve deleted photos from the camera, garbage can or memory card?
First of all, you should stop saving any new files to you canon camera (or SD card) or taking new pictures with you camera.
Then find this card recovery software here
Here are the steps:
Step 1: Download and install the Digital Photo Recovery Software from
http://www.asoftech.com
Step 2: Connect your camera (or SD card, memory card etc) to you PC
Step 3: Scan the source drive where your lost pictures located.
Step 4: Recover the lost pictures and save them to another drive instead of the source drive.
Aug 30, 2011 | Fuji FinePix S1000FD Digital Camera
I have a panasonic lumix camera and there are a selection of photos which i want to delete. When i try to delete them there is a message saying 'this photo can not be deleted'. These photos are not...
Maybe you just lock the memory card of your camera. Take the card and unlock the lock of you memory card, simlpy slide the button according to the icon display. Then Plug it again to your camera and repeat the steps you made.
Aug 25, 2011 | Cameras
The memory card is locked! I don't know how this happened but I want to delete the photos. How do I unlock the card and delete all the photos
Depending on the card, there may be a little slide lock on the side that you can move with your thumb to lock and unlock.
Aug 23, 2011 | Cameras
Cameras Logo
1,123 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
