Soniq QSP422T LGEPDP might be a sustain board problem
Soniq QSP422T LGEPDP problem
am an old CRT electronics tech been out of the TV scene for many many years. dont know bugger all about plasma's. so forgive the newbie questions. the power supply is all good, but the HV (posibly the SUSTAN PCB) LGEPDP board model 42X4 has a blown fuse and and VSS is short to ground. there are 2 long ribbon connectors that connect to the PDP. I guess its like a LOPT HV supply in CRT terms :)
imagine replacing the whole module/PCB labeled 42X4 might go alright but what are the chances the plasma display panel electrode thingys are shorting at HV and destroyed this board. how often do plasma displays go short. both electrodes/connectors are very high resistance to each other and ground,but i have no idea what V they operate at or the risk in trying to replace this board???
do plasma display panels fail often ??
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Mar 13, 2017
2 Suggested Answers
  • 208 Answers
SOURCE: LG 42PC3RV module LGEPDP burned hybrid IC
If the buffer drive bds. were replaced along with the ysus and zsus and this problem occured it is definately and defective pdp.
Posted on Feb 15, 2008
Night seens are very dark
Call a good TV Tech and have him check all crt anodes for proper connection. Also remove & reinstall all crt boards, clean spark gaps. This TV is also known for having bad convergence amp IC's.
Jul 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Tv picture will not come on standby is flashing
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Apr 23, 2009 | Sony KV-36FS100 36" TV
Tv dead,checked fuse plug OK
If the TV goes off completely, then is usually a faulty power board.
On Rear Projection / LDP : check lamp, lamp ballast, power board, and convergence.
Mar 27, 2009 | Televison & Video
TIMER/STANDBY LIGHT IS FLASHING
connected.
Feb 21, 2009 | Sony KP-53HS10 TV
Cant turn tv on when red light is flashing
connected.
Feb 13, 2009 | Bush WS6671 28" TV
Tv keep flashing.
connected.
Feb 02, 2009 | Sony KV-32S40 32" TV
32" rca 32v524t
connected.
Jul 13, 2008 | RCA 32V524T TV
HP MD5880n TV Screen flashing
connected.
Jul 07, 2008 | HP PL4245N 42 in. HD-Ready Plasma...
Bush 26 lcd tv
connected.
Apr 05, 2008 | Bush 5693D 24" TV
X and Y Sustain Boards
How is the picture displayed? Distorted or dim?
Dec 03, 2007 | Philips BDS 4611 46 in. Plasma Television
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
