Question about Whirlpool Washing Machines
Black grease spots on clothes after the wash I have a simpson espirit 750 washing machine
  • Whirlpool Master
  • 713 Answers
Hi just read your posting.Are you 100% sure the black marks are grease or oil?If you are then the only place the oil comes from is the gearbox.This means that to repair this fault you need a new gearbox.Unfortunately the repair is not cheap so I would recommend getting a service tech out to confirm.Every time I went to a customers house and I saw this problem then I would tell them the same thing.Once again sorry for the bad news and please reply if you need any more help or advice.Good luck.
Posted on Jul 11, 2010
Testimonial: "Thank you very much for your help I went and purchased a new machine because we live in such a disposable society. Thanks again Domenic"
Washing machine, Simpson Espirit 500, won't start at all. Power is on and water, cold turned on as well.
Possibly the door switch isn't working or is maladjusted so the machine's brain thinks the door is still open.
Feb 18, 2017 | Simpson Washing Machines
My simpson eziset 750 is leaving grease marks on clothes after wash. Whats wrong?
Do you use fabric softener? Too much softener & too many cold water washes results in a build up of black soap residue on the outside of the inner bowl. You could try a hot wash with some white vinegar in the water (No clothes just the water) If that doesn;t work then you will need a service person to come & take the bowl out for cleaning.
Jan 02, 2016 | Simpson Washing Machines
Eziset 750. Why is it leaving grease marks on clothes after wash?
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Oil on cloths after wash
Simpson washing machines are known for this, The seal in to top of the gearbox fails which allows water to enter the gearbox, this forces the grease out of the gearbox into the machine, The fix is an expensive gearbox swap.
Mar 11, 2012 | Simpson Washing Machines
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson eziset 750. During the wash cycle, it does not agitate in both directions, it will only turn in one direction, then stop and pause like it wants to turn in the opposite dirction, then turns in...
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Oct 14, 2010 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
May 30, 2009 | Washing Machines
My simpson espirit 700 has been in storage for
check first the continuity of the power cable. next is the fuse if it is not busted. then try to open the control portion there might be some coroded contacts.
Apr 07, 2009 | Washing Machines
Washing Machines Logo
277 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
