Question about Canon PIXMA iP4200 InkJet Photo Printer
Only Prints in Magenta
Hello
I just changed my cyan cartridge and now my canon ip4200 will only print in magenta! Up until I changed the cyan, everything was working perfectly*
Help?
*well except cyan cartridge was empty
    Genius:
  • 1,689 Answers
The cartridges may still be at fault, or there is a problem with the processor board in the printer. I have also seen problems with the ink jets in these.
Jerry G.
Posted on Apr 19, 2008
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
I've a canon MP610 printer and I cant get good colour prints, they are too red. Even when I try to print B/W they turn out brown. I've printer direct from the memory card and the same results. I use canon...
Do you have photo cyan or photo magenta installed? your machine does not use these inks, and will give wrong colors. You need plain magenta and plain cyan. If you are using generic inks, they could have bad colors too.
Aug 10, 2009 | Office Equipment & Supplies
Printer prints wrong colors
As a guess you have the color ink cartridges in the wrong places. Take them out and run a whole bunch of head cleaning routines. I'd expect the wrong colors for a while until the incorrect ink has been flushed out.
Check your manual or setup guide for the actual order . Usually black-cyan-magenta-yellow
Jul 09, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Cartridges don't work
Sounds like you got a defective cartridge, it happens once in a while. On some Canons, you hold the resume button for 5 seconds and it will ignore the error, not sure on your model printer.
Jul 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon MP 730 prints wrong color tones
I was having a similar problem-- what was happening was the print cartridge head seemed to be letting the colors leak into each other. (the science behind this is beyond me!)-- I noticed that instead of being cyan/magenta/yellow, my yellow cartridge had actually turned green, magenta was picking up blue and was turning purple, etc etc. I ended up replacing the printer's printhead and all the color cartridges and then it worked.
You can order printheads online.
Not sure if this fixes the original reason why they got all mixed up in the first place-- if the printer will continue to allow the print head to leak the colors into each other-- but hopefully that's a fixit!
Aug 10, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Only prints in magenta
if your cartridges are new one then do this, reinstall printer driver and check in the printer driver features that you have selected print in black and colour option
Apr 02, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Magenta ink colour
I had the same problem. Try cleaning the print heads. They tend to clog. Remove the cartridges, then remove the print head. Tilted slightly, it comes out easily. Run very warm to hot water over the print heads until they all run clear. Use a turkey baster to apply strong pressure to each head until it runs clear. Blow off the excess water with mouth or blow dryer. Insert into the printer and proceed to print. If that doesn't solve it, you might have a bad cartridge, but there isn't much that can go wrong with the cartridge. I have an ip4200 and an MP830. They have the same print heads and same cartridges. I have cleaned each twice and they work like new.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
169 people viewed this question
old marine
old marine
