Question about Hotpoint Washing Machines
SOURCE: Aquarius Hotpoint WD440. 1400 Spin
hotpoint Wd440. I had the same problem, lights flashing and water not draining, First drain your water (syphoning works but tastes ****), if the machine drains then you know its not blocked. Then put the machine on M for about 5 mins, then put it on fast spin. This should do the trick, it worked for me anyway. Good luck.
Posted on Aug 10, 2008
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
Posted on Jun 27, 2009
SOURCE: Error code H20...My washing machine, a hotpoint
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Posted on Mar 02, 2010
SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The
filter is inside the machine. Turn off the power and pull out the machine to
get to the rear. Pull out the hose you
see going into the wall pipe, lay at floor level or plastic bag to drain out
remaining water in machine. Remove the panel at the bottom (2 screws) where the
discharge hose comes out. You should see a black concertina type tube coming
from below the drum attached by a jubilee clip. The filter is inside. Loosen
the clip and pull away the tube, take out the filter and clean it. When you
replace it don't forget to put the ball float back in (exactly as you found it)
and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at
the exact location where you found it, abt three feet up from ground level.
Pl
rate me nice for the free help, thnks.
Posted on Jun 04, 2010
Oct 19, 2012 | Hotpoint Aquarius WD640 Front Load...
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Jun 13, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Jun 09, 2008 | Hotpoint Aquarius WD640 Front Load...
187 people viewed this question
