Will not install correctly - Computers & Internet
  • jdh1963 Apr 24, 2008
    I just did a system restore and resolved the problem.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    What will not install correctly?
Macromedia flash program I got it figured out . Thanks
Posted on Apr 20, 2008
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
Change spark plugs fuel filter fuel pump engine can not start
Wow! You've really got your hands full! 1) Verify the fuel pump is installed correctly and has power. 2) Verify the fuel filter is installed correctly. 3) Verify the spark plug wires are correctly installed. The number one reason for a car not running after an owner changes the spark plug wires - the wires were not installed to the correct cylinder.
Sep 22, 2014 | 2000 Dodge Stratus
I can not install my realtek high definition audio driver
If driver fails to install, its most likely not correct driver. Download the correct driver for correct OS from manufacturers web-page. You can also try to find correct drivers from your laptop manufacturers site by using laptop serial number / product number.
Apr 18, 2014 | Computers & Internet
CORRECTION RIBBON
The correction ribbon is installed on a separate mechanism on a typewriter. If you look between the regular ribbon guide and the card holder you should see the correction ribbon guides on the right and left hand side of the card holder. the spool holders will be to the right and left of the correct ribbon guides. This is true only if the typewriter has a correction mechanism installed. Some machines do not have a correction mechanism. Correction is achieved by using a correction tab which is held by hand, in front of the letter to be removed, or white out. Some correction tapes attach to the bottom of the print ribbon.
Nov 06, 2013 | Swintec Office Equipment & Supplies
I am having problems changing the correctable ribbon. It does not correct after installation.
if it prints but doesn't correct, it is probably a problem with the correction tape. make sure the tape is instaled in the correct postion with the dull side towards the paper
Mar 14, 2011 | Brother GX-6750 Typewriter
I have installed my abit nf8-v2 motherboard into my computer but i can not get my computer to power on. LED 2 is turning on but not LED1
Please verify that you have completed the following:
  1. Connected the cables from power supply to the motherboard
  2. Connected the processor fan power connector
  3. Installed the memory correctly
  4. Connected IDE/Sata cables correctly
  5. Processor installed correctly with fan sitting correctly
Feb 08, 2011 | Abit NF8-V2 ATX Motherboard with NVIDIA...
"Bijoy is not installed correctly.
'please install BIJOY correctly in my computer'
Feb 03, 2011 | Microsoft Windows 7 Ultimate for PC
My printer will not install
Are you expecting for the disc to be auto run? not sure if you are using the correct disc to install the correct driver on the OS .. you need to make sure this is correct first before installing it.. below link might be hepful to resolve your issue and getting the correct driver
http://etech.maiila.com/canon-pixma-mp210-photo-all-in-one-printer-driver-manual-and-software
good luck
Nov 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Correction ribbon
make it sure that the correcting ribbon correct insert to the guide of the ribbon push it then you feel lock , test correcting not jumping ribbon case , then ok.
Dec 11, 2007 | Brother GX-6750 Typewriter
Hp 3015 not installing
Problems seem to occur when printer cable is plugged in before software is installed.
Delete driver and software installed, disconnect printer from PC.
Download and install correct driver to suit, connect usb when software prompts to do so
Make sure the driver you are installing is correct for you system
LINK to DRIVER DOWNLOAD
Nov 18, 2007 | HP LaserJet 3015 All-In-One Printer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
