Question about La Crosse Radio Controlled Atomic Clock
Good morning! I have replaced the batteries in my wall clock model #9n6 v00u and the indoor receiver is not showing the outdoor temp. I have pushed the reset button and nothing changes what am I doing wrong?
5 Suggested Answers
Palmbeach
  • 185 Answers
SOURCE: Radio controlled clock won't set
I'm sorry to hear that.
It sounds like no pulse signal is being received by the clock then. This can only mean the transmitter site has a long term problem, which is unlikely. Or your clock's receiver is faulty. Sorry, cannot offer any other suggestion. You could just leave it running, it may pick up a pulse eventually and get back on track. I guess there is nothing to lose in trying, except a couple of batteries.
Take care now!
Posted on Feb 16, 2008
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Posted on Oct 22, 2009
dunnbiker
  • 8546 Answers
SOURCE: We have an Atomic Lacrosse
Directions:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
support@lacrossetechnology.com (warranty work)
sales@lacrossetechnology.com (information on other products)
web: www.lacrossetechnology.com
Posted on Jan 19, 2011
I have the weather channel indoor outdoor thermometor and the outdoor temp and humidity are not showing up on my wall reader
With mine, this indicates that the battery needs replacing on the INDOOR unit. For some reason they don't pick up the signal from the transmitter. I use batteries 3 to 1, indoor to outdoor.
Feb 23, 2017 | Weather Channel Measuring Tools & Sensors
Will not transmit outdoor info. Batteries good- LED lights. Monitor shows indoor temp only.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
May 23, 2015 | Measuring Tools & Sensors
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
My wall clock quit showing outdoor temp. it has
Wall clock quit showing outdoor temp. Batteries are fresh.
Nov 25, 2009 | SkyScan 86709 Atomic Wall Clock
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
La Crosse Radio Controlled Atomic Clock Logo
94 people viewed this question
Top La Crosse Home Experts
David Burbee
David Burbee
Are you a La Crosse Home Expert? Answer questions, earn points and help others
