Question about Fisher and Paykel GWL11 Top Load Washer
Faulty computer - Fisher and Paykel GWL11 Top Load Washer
  • salngeorge Jul 11, 2010
    the 3rd, 4th and 5th lights come on together (from left to right),the machine beeps and stops before the rinse cycle and won't progress any further? what error is this?
    President:
  • 2,468 Answers
Do you know for sure its faulty or are you asking if it could be your problem?get a make and model number and problem(s) your having and i will try to assist you on this matter further
Posted on Jul 11, 2010
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now can you tell me why you think your computer is faulty.Does it come up with an error code or is the computer not powering up?If it does come up with an error code there will be a beep and a series of lights will be lit when it is beeping.These lights will be in a row of 8 lights.What I need to know is what lights are lit in this row.Starting from left to right on the row which lights are lit?Is it the 2nd and 4th or the 3rd and 6th -0--etc---?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
  • 2 more comments
    on the console, it's the 3rd, 4th and 5th green light that comes on together and the machine stops and it beeps to tell me something is wrong.
    have I given you enough information?
  • luisa_sgro Jul 11, 2010
    Hi just read your posting.The error code you have indicated is BOWL CHECK FAULT.The primary source for this fault is the clutch is not re-engaging.Open the lid of the machine and try lifting the inner bowl up and turning it and then releasing it to see if it re-engages.If the inner bowl has not re-engaged the clutch then you will not be able to lift it up as its position will be already at the top under the neck ring.The secondary source of the fault will be the ROTOR POSITION SENSOR with is located on your motor.Try the inner bowl check 1st and reply on how you got on.Sorry I did not get back to you sooner but there was something wrong with the web site.By the way did the machine fill with water and wash and only faulted when the cycle reached rinse or spin?Looking forward to your reply.
    Just read your last posting.You mentioned that the machine stopped before the Rinse cycle>Did the machine drain the water?Please reply as the web site is now working properly.
What are codes p1401 p0302 p0305 p1409 p0301
P1401 Differential Press Feedback EGR Circuit High Input
Your EGR port is plugged. Replace your EGR valve, and clean the ports
A code P0302 may mean that one or more of the following has happened:
  • Faulty spark plug or wire
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Running out of fuel
  • Poor compression
  • Defective computer
  • A code P0305 may mean that one or more of the following has happened:
    • Poor compression
    • A code P0301 may mean that one or more of the following has happened:
      • Poor compression
      • A code P0302 may mean that one or more of the following has happened:
        • Poor compression
        • p1409
        • EGR Vacuum System Leak - Read Our Article on EGR Valve Codes For Help With This Oldsmobile Check Engine Light Code
Sep 25, 2014 | Cars & Trucks
N computing L230 restart automatically
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
May 25, 2011 | Computers & Internet
Faulty Power Circuit board Short Circuit on Motherboard Malfunctioned circuit on mother board Faulty Motherboard, Power supply not working Power does not flow through the circuit board Faulty Circuit...
Test your power supply unit if the PSU units fans not working its faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error computer error a computer needs its connections continue its cycle and have an end to function
hope this helps
May 12, 2011 | IBM 41D2469 Motherboard
I have my computer plugged in and there is a blue light on but the computer will not turn on
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 03, 2011 | Targus Televison & Video
Computer wont come on. Is there a power lock button
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Apr 17, 2011 | Computers & Internet
Computer will boot up
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help you
Mar 14, 2011 | ASUS (90N804SH021) Hard Drive
Computer broke
you have not stated what is not working so i have to guess you need an overhaul
hope this will help don
Mar 09, 2011 | Boston Acoustics BA735 Computer Speakers
My computer restart automatically
hope this will help
don
Feb 25, 2011 | Microsoft Windows XP Professional
Computer turn on then off
hope this helps
Feb 03, 2011 | Dell Computers & Internet
No signal keeps appearing
This message means the monitor is not getting a video signal from the computer.
This could be a loose video cable, a faulty video cable or a faulty video card.
It is possible the monitor is faulty, try connecting it to another computer with a different video cable. This will tell you if the monitor is faulty or not.
Sep 14, 2009 | Acer 22" X223w LCD Monitor
Fisher and Paykel GWL11 Top Load Washer Logo
93 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
