Question about Tamron 18-250mm F/3.5-6.3 AF Di-II LD Aspherical (IF) Macro Lens for Konica Minolta and Sony Alpha D...
Damaged Lense I have Tamron 18-250mm lenes & dropped it & now it will not focus on auto any more but OK on manuel. Will it be repairable & at an economical price. Ray Tucker
    New Friend:
  • 3 Answers
Does the camera recognize it? I mean when it is attached, does the camera show the Fstop etc?
Posted on Nov 04, 2013
2 Suggested Answers
  • 4 Answers
SOURCE: I have a Tamron lense 18-250mmm for Canon. It does
In low light situations, connect a speedlite flash to your body (e.g. 430EXII or 580EXII). These flashes emit a AF assist beam to assist focussing in low light situations.
Posted on Jan 04, 2010
I bought the new Tamron 20-200 lens and after trying it on my Canon 7D non of my lenses will focus on that camera. What has happened?
Sure you did not switch to manual focus while testing the Tamron? Sure all settings are correct?
If the Tamron still auto focusses on you 7D, check the forums about this. I know Nikon sometimes messes up the firmware, when a non Nikon lens is used, but not on all camera's. And not with every firmware.
I don't know the 7D enough to check more details, but check everything about the AF settings. I can't imagine your lens did something wrong with the camera.
Jan 07, 2015 | Canon Cameras
Want inexpensive 2x af teleconverter for d70 nikon lens 80-200 ed
You can order the Tamron 2x teleconverter here. Be aware that not all lenses are compatible with teleconverters, and you can actually damage some lenses by trying to use them with a teleconverter.
Jul 14, 2012 | Tamron 2x Auto Focus Teleconverter with...
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
Aug 08, 2010 | Tamron 55-200mm f/4-5.6 Zoom Lens for...
Auto focus not working
Sorry but if you've tried all the usual fixes then there's nothing more that you can do. Either pay for a professional repair or continue to use the lens manually.
A professional repairer should be able to indicate what the likely costs are going to be and you can then judge whether repairs are cost effective.
Personally, I'd stick to manual focus as I've always preferred knowing exactly what I'm focussing on instead of constantly fiddling with buttons and menus to override what the dumb camera has locked onto.
Aug 22, 2009 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
I broke the top lens on my Tamron AF 70-200mm f/2.8 Di LD IF Macro Lens. I dropped it. Does anyone know how to order just the lens? I can replace it myself. Everything else on the lens is fine.
Contact Tamron USA via their web site or a phone call to get a price quote for the front lens assembly. However, I would strongly suggest that instead you allow Tamron to repair your lens since more than likely the internal roller glides have been compressed due to the impact. This would allow the front lens group to wobble a bit while focusing and zooming, and this would seriously affect the image quality.
Mar 15, 2009 | Cameras
Auto focus problem
My first suggestion is to send it back if it is under warranty.
The grease probably got so thick, from the cold, that it caused too much resistance for the auto-focusing mechanism. You probably have damaged the focusing mechanism in the lens. You cannot repair this, yourself. I don't know how cold is too cold but it really shouldn't have done that.... Tamron makes cheap lenses. Try and exchange it for at least a Sigma.
Dec 24, 2007 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Tamron 18-250mm F/3.5-6.3 AF Di-II LD Aspherical (IF) Macro Lens for Konica Minolta and Sony Alpha D... Logo
103 people viewed this question
Top Tamron Cameras Experts
Jerry Greenberg
Jerry Greenberg
TC CAMERA REPAIR.Com...
Are you a Tamron Camera Expert? Answer questions, earn points and help others
