Question about Dryers
Ariston a1600wd washer/dryer No matter what setting i put my dryer on, it doesn't dry anything. it spins around as though it is going through the cycle but nothing, but when it is finished the washing isn't dry.
When the filter gets blocked the dryer doesn't work.
The filter is located behind the small panel to the rear of the machine.
Remove the three screws and then the plastic panel.
The filter is located in the large black rubber gater tube which is held on by an adjustable clip.
Remove the clip by unscrewing the philips head screw and pull the tube down to remove. The filter has what appears to be a table tennis ball inside. Apparently this helps with self cleaning!
Remove the filter, clean and replace. The filter needs a little fiddling to get to sit right. Replace the gater tube and re-fit and tightend clip. Check for tightness and set the machine away and check for leaks etc. This job takes about 20 minutes.
If this doesn't solve the problem you will need to focus your attention to the heater element or thermastat located on the top of the machine behind a cast plate help on with torque screws.
Hope this helps.
Posted on May 23, 2009
Take the top off and look for an orange wire, is it broken? Mine was, repaired it and it works great now.
Posted on May 11, 2009
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
My ariston margarita dosent want to take a wash load
Most likely the EPROM is gone, or more commonly known as the PCB (Programm Control board) and it needs replacement. Costs about £80 for the board plus installation.
Dec 14, 2009 | Ariston Technologies Ariston AWD12 Front...
What do i do
try manually moving the knob through each cycle until it gets back to the finished cycle. or the timer may need to be replaced
Jul 30, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston a1600wd not working
There is a filter of sorts in the pump inlet pipe, its a big item catcher coins etc, but thats got nothing to do with the module error wich is a pricey item at £120! I've had one go already and in the last year, a inlet valve plus a control pcb panel in fact its almost a NEW machine! i'll never buy another hotpoint or ariston again. The machine is two yrs old!
Oct 02, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Ariston washer/dryer. Dryer not working
Assuming everything else is working, it sounds like your heating element is burned out. Two years is a little short for the typical life span but not unthinkable.
Here's a photo of the part for your unit at a site that sells them. If you pull the back panel off and trace the wires, you should be able to find this part easily. It is designed to be replaced.
Sep 23, 2008 | Dryers
probably 2 separate faults no heat is possibly either open circuit on the elements which are at the top of the machine, or open circuit thermal cut outs (up to 3 of) located also at the top of the machine near to where the element is and along the flow of the hot air, you can check these with a normal electrical multi-meter, unplug machine before testing as for the vibration on spin, just look for any loose suspension legs, and or twisted drum alignment, very difficult to work on due to lack of access but sometimes just re-tightening the legs up etc, could cure the vibration hope i have helped you to start somewhere take care to note in detail any wires or parts removed or in case of accidental removal
Sep 27, 2007 | Ariston Technologies AWD121WH
Ariston margherita 2000 advantage AWD10
Push the sun symbol button and set it on the time/or the function of the dryer. Thats it. I believe you were using the drying function without heating:)
Regards
Jan 24, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Dryers Logo
613 people viewed this question
Top Dryers Experts
